Throttle Body Clean.
nickelvery May 21, 2007
  1. nickelvery
    nickelvery RS4 B5 380bhp
    545
    :jester: I'm going to clean my throttle body tonight but I read from a different forum that you have to reset the throttle with VAG-COM after cleaning it?
    Is this true or will a ECU reset do the same?
  2. rodenal
    rodenal Active Member
    1,992
    Unplugging the battery will do the same thing, the engine will cycle the throttle body on plugging it back in.
  3. nickelvery
    545
    Nice one.
  4. twist
    twist Member
    84
    Let us know how you get on, I plan to do this, this weekend. As mine has done 100K
  5. nickelvery
    545
    :jester: Will do.
  6. jonS3
    jonS3 Member
    719
    I did this a couple of weeks ago, mine was filthy :(
  7. nickelvery
    545
    I took off the hose on the right off the picture and removed the 2 screws highlighted with red circles.
    But when trying to get the throttle body off it wouldn't move.
    Am I being really stupid or does it need a good bash?
  8. Dave_Bayern
    Dave_Bayern Slipping at 3.5Krpm
    1,913
    There is another two screws underneath............
  9. nickelvery
    545
    How stupid of me of course there is!!!:idea:
  10. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    Use some brake cleaner or isopropyl alcohol to clean it out, wont damage anything.
  11. nickelvery
    545
    Do i really have to get a new gasket for it?
  12. jonS3
    jonS3 Member
    719
    would obviosuly be best to change it, but as long as you dont damage it, and tighten up each bolt a little at a time when putting it back on it will be fine
  13. Stewart
    Stewart Member
    705
    10
    Just to add that after the throttle body has recalibrated itself the car will go through the adaptation process and may feel not quite as quick for a while.
    Nothing to worry about.
  14. madvw
    madvw Active Member
    2,489
    funnily enough, i've always found a car to be faster during the re-learn miles than when its settled down.
  15. nickelvery
    545
    Is that the same for a Revo remap, can they adapt?
  16. Spacecowboy
    Spacecowboy Member
    367
    Think I will try this this weekend. Are we supposed to drive in a particular way when the car re-learns i.e. under so many revs etc etc? Anyone know the part number for replacing the gasket and is there a torque setting for the bolts?
  17. Stewart
    Stewart Member
    705
    10
    Just drive how you normally would, there is only a small range of adaptation anyway.
    I believe the torque setting is 8Nm.
  18. Spacecowboy
    Spacecowboy Member
    367
    Cheers buddy
  19. campbell
    campbell Member
    721
    curiously, what are the mileage on peoples cars?mines on 59K and just wondered if its worth doing!?
  20. Caesium
    4,879
    is it worth doing on an oil-burner?
  21. madvw
    madvw Active Member
    2,489
    tbh, mileage is pretty much unimportant - its the type of journeys you make. It's far more likely to gum up more quickly by doing slow stop start journeys.
  22. Pat
    Pat Member
    515
    I did mine last night.. just taken itout and it feels far more responsive.. Mine had done 60k and was filthly
  23. Defratos
    Defratos You’re Dethpicable!!
    2,232
    Wow, ok whenever I've cleaned my throttle body I've never removed these screws. I just remove the silicon/rubber pipe connecting the throttle body to the IC and clean it through there. Have I been doing this wrong? because it seems like you guys remove the "whole" throttle body out of the car, is this right?
  24. Pat
    Pat Member
    515
    Yeah its better to take it off as you are only cleaning one side of the body.. Mine was covered on both sies of the flap..
  25. Defratos
    2,232
    and its ok to move the flap around to clean it? and would I need another gasket? How does this look?
  26. madvw
    madvw Active Member
    2,489
    no way!! not unless you have a cable operated TB. The stepper motor must not be moved at all.
  27. mrj0ey
    mrj0ey Member
    105
    I moved the flap thingy loads, car was way better after the clean, no issues here!
  28. cjhill
    cjhill hmmmmm interesting.
    335
    right, just finished cleaning the throttle body, tbh i cant say it has made any difference.
    It was filthy though - im sire worth it in the long term
  29. twist
    twist Member
    84
    I did it on the weekend just gone. Didnt make much difference wasnt very dirty though. Good for piece of mind though
    I thought the Radio would need the code putting in it didnt is this normal?
  30. Caesium
    4,879
    Yep, had my radio out about 10 times, never asked for it. I think it interrogates the ECU and as its connected to the right one it doesn't ask for code.
  31. Dave_Bayern
    1,913
    Yup, its called CANBUS.
  32. garratt83
    garratt83 Member
    244
    Just thought i'd let you all know I did mine yesterday and it was a complete mess, cleaned up really well. Only problem is I snaped a breather hose. Only a small one but it was so brital. Going to audi today to see if they can supply me with the part. If anyone know waht I need to ask for heres where it goes
    It goes from the air intake pipe, under the throttle body, along the back of the engine and connects to a pipe at the back.
    Oh and I had to put my radio code in when I had finished but I did have the battery off for over an hour.
    Car seem a little better but I'm being a bit careful until I get a new hose.
  33. Caesium
    4,879
    Thats bizzare about your radio, I didn't use my car for over 3 weeks and the battery went completely dead, the radio still didn't ask for a code.
  34. garratt83
    garratt83 Member
    244
    yeah my radio turned in to a scally and said 'SAFE' to me.
  35. madvw
    madvw Active Member
    2,489
    the battery went dead on my s3 (partial can-bus) and the rns-d needed a code.
  36. Caesium
    4,879
    It was just being "street" with you
  37. garratt83
    garratt83 Member
    244
    SOUND!!!!!!!!!!:rockwoot:
  38. Caesium
    4,879
    I believe thats the purpose of the Radio....:ermm:
  39. Smoke Breather
    Smoke Breather Member
    94
    Going to have a go this myself along with the MAF but I haven't got a clue where to get some of this Isopropyl, Blackpool doesn't seem to have a n Isopropyl Shop or even an "Isopropyls R Us", can anyone give me a clue?
    Cheers All :icon_thumright:
  40. Dave_Bayern
    1,913
    Isoclene from a computer cleaning product website, or go into your local proper pharmacy (not boots) and tell them you want some isopropyl for cleaning. Failing that Maplins and RS and CPC all do it.
