This pic will have to do
dieselfitter251 Nov 18, 2008
  1. dieselfitter251
    dieselfitter251 Blow ma own trumpet?
    1,120
  2. aragorn
    18,490
    855
    looks it to me!
    Which sensor is that?
  3. dieselfitter251
    1,120
    left rear , I was hoping that it might be ok after it'd been cleaned
  4. dieselfitter251
    1,120
    Still activating the left rear ABS at 20mph approx.
  5. dieselfitter251
    1,120
    What am i looking at in VAGCOM measuring blocks, in the groups bits. Of the 4 channels in group 2 I've got one that read n/a.
    I've got, error group 3 not available
    Group 4. Clock = .10 two channels for 'bin bits' and the ladt channel n/a..
    And I also get a VAGCOM error saying to many communication errors to continue!
  6. dieselfitter251
    1,120
    I think the next plan is to swap the sensors form side to side, see if its an actual sensor problem (I think it is in the case of the left rear) or a control / channel / or wiring problem...
    any thoughts?
  7. aragorn
    18,490
    855
    i dont know what you can view in the vagcom screen as ive never looked at my ABS module, but is it logging any fault codes for that dodgy looking sensor?
    Try unplugging another sensor to see if the output in the measuring blocks changes noticably?
  8. dieselfitter251
    1,120
    Aye,
    00285 P1716 ABS Wheel Speed Signal #2 (Right Front) - Range/Performance - G45
    aaaaand...
    00290 P1726 ABS Wheel Speed Signal #4 (Left Rear) - Range/Performance. (G46)
    these were from the manual, my battery died just as I wa copying & pasting..
    My main concern is that I've got a goosed channel or something on the front right, that sensor is brand new, I can understand about the rear left as it's in a bit of a state.
    What are the possiblities of it being the hub that's git the problem? I've looked in at the ABS rings and tbh they both look fine on rotation.
  9. dieselfitter251
    1,120
    *[UPDATE]*
    I'm going for lunch, then I've got work to do on some new arrangements for a jazz sextet I'm getting off the ground. The damn car sit and beep it's feckin head off or drag it's feckin gimpy left rear all it feckin wants.... I'm hungry.
  10. aragorn
    18,490
    855
    did you try closing up the gap on that driver side front sensor?
  11. dieselfitter251
    1,120
    aye, pushed it right in still it was solid then pull it back about 1mm, spun the hub to make sure there was no scraping sound...
    It may be Saturday til I can get back into it but I'm going to swap the sensors around, I think I'm in for bad news.
    As for the rear. Did you say you had some sensors lying around?
  12. aragorn
    18,490
    855
    nah auoran is breaking a V6, not me.
  13. dieselfitter251
    1,120
    A'right. CHeers!
