This is one of the things I like doing with my S3
S3fan Jan 31, 2009
  1. S3fan
    S3fan Kiteyboy
    372
    cruising along at 80 - 90, about 3500 revs...getting the brain to pump a half pint of blood to the base of my right foot (you need the sprintbooster fitted to appreciate the effect), and then feeling it go.
    I also like cleaning it.
  2. alijames
    alijames Active Member
    1,024
    I should get organised enough to go on a track day too...:blush:
    (Or find a private road!!)
    Cheers,
  3. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,209
    2,029
  4. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    how is the sprintbooster..ho much difference did it make?
  5. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    try that in a car thats 1200kg and 315bhp. its fun:yes:
  6. S3fan
    S3fan Kiteyboy
    372
    Well a lot of people think its witchcraft playing about with the electronics, but I reckon it was £100 well spent. It transforms the response you get from the throttle. A slight squeeze and it responds.
  7. S3fan
    S3fan Kiteyboy
    372
    I was referring to the unrestricted roads of Europe Jase....not the m6 Toll road
  8. HTC
    HTC Active Member
    3,428
    9
    I hate washing cars.
  9. Dani_B19
    9,320
    389
    so true, especialy when it reveals someones srcaped your f***ing front bumper again :banghead:
  10. Westy
    Westy Well-Known Member
    17,443
    1,104
    I've never heard of sprintbooster before but just looked it up and it sounds very interesting. Where do you order them from? The website I found wanted £170 which is a tad steep for a new throttle controller!
  11. Dani_B19
    9,320
    389
    That sounds about right, ive shopped around and found them for £140 (ebay) before but youve got to add on the cost of fitting them because i think thats around £70-90 for fitting, could be wrong but in the end i know there not cheap. hope that helps.
  12. S3fan
    S3fan Kiteyboy
    372
    Jon at VAGTech had one and did a special price for me. It took him 15 mins to fit it.
    I spent £100 on it, and to me it was very good value for money.
    Audi Driver did an article last year about it.
  13. Dani_B19
    9,320
    389
    In that case you got yourself alittle bargain
  14. Westy
    17,443
    1,104
    Surely fitting it yourself cant be too difficult?
    any links to the article from Audi Driver???
  15. S3fan
    S3fan Kiteyboy
    372
    I would imagine not
    No, just something I saw when I was browsing in Borders
  16. ianysm
    ianysm Active Member
    1,002
    Sounds interesting, what exactly are they then...Surely a chip is far better!
  17. Westy
    17,443
    1,104
    Its nothing like a chip as it doesn't tune the engine. Its supposed to improve throttle response and it does sound like it would be a worth while mod.
  18. Dani_B19
    9,320
    389
    Most cars in the 21st century have replaced the more conventional throttle cable for an ECM (Electronic Control Module) that translates how hard the pedal is pushed into electronic signals in order to provide power to the wheels.
    The ETC (Electronic Throttle Control), which is also known as Drive-By-Wire, has the unfortunate downside of delayed response and subdued acceleration, which can create problems in certain situations such as up-hill starts, quick gearchanges and overtaking. The Sprint Booster aims to overcome this throttle response delay for ETC equipped vehicles, by providing crisp, on-tap acceleration for whenever the driver demands it. Get more from your car, fit a Sprint Booster now!
    Results[COLOR=#fffff]
    • At low revs, the engine responds at approximately half the time in comparison to before.
    • The delay time whilst accelerating in 3rd and 4th gear and the engine in the mid-range, is almost zero.
    • Big differences in the higher rev range.
    • Improved response for downshifts and safer overtaking.
    • Overall safety and more fun on the road!
    [/COLOR]
  19. Dani_B19
    9,320
    389
    How to Install the Sprint Booster[COLOR=#fffff]Follow the instructions below to install your Sprint Booster, or you may print out these instructions by downloading the PDF HERE. You will need to acquire the free Adobe Acrobat reader, you can do this by going to www.adobe.com. Step 1 >>
    Remove floor mat
    [​IMG] Step 2 >>
    Remove plastic cover and undo allen headed bolt
    [​IMG] Step 3 >>
    Slide pedal upwards and then towards you. Unplug wire connector
    [​IMG] Step 4 >>
    Plug in the Sprint Booster, then push the body of the Booster through the hole in the carpet to allow clearance for the pedal to go back into position
    [​IMG] Step 5 >>
    Slide the pedal back over the metal tab on the floor and replace the bolt and plastic cap
    [​IMG] Once Fitted
    Sprint Booster does not affect your insurance or MOT certification
    note: these are general instructions applicable to most vehicles, some vehicles may require additional fitting
    [/COLOR]
  20. Dani_B19
    9,320
    389
    hope they help
