butler2.8i
Products and equipment used
Uber microfiber towels
Uber drying towel
Valet pro bilberry wheel cleaner
Valet pro tyre gel
Valet pro orange pre wash
Valet pro PH neutral snowfoam
Valet pro citrus bling
Valet pro Talos Protectant
AMDetails AMbubbles
Autosmart Tardis
Makita rotary polisher
3m Yellow pads
Dodo juice Limeprime
Bilt hamber soft clay bar
Various wheel brushes
Karcher pressure washer
Noodle wash mitt
Lambs wool wash mitt
Poorboys microfibre clothes
Snow foam gun
Chemical Guys Jetseal 109
Autobrite Obsession
Ironx
Rainx
Autosol metal polish
00 grade wirewool
The car before I start
I cleaned the wheels using the bilberry wheel cleaner and various wheel brushes and a noodle wash mitt, the bilberry got the worst of the muck off just leaving some iron build up to be removed by the Ironx. Slight build of tar was also taken care of by some Autosmart Tardis
I started by giving the lower parts of the car a coat of the valet pro orange pre wash, which was left to dwell before being pressure washed off. The car was then given its first coat of snow foam made up of the valet pro PH neutral snowfoam, the snowfoam was then blasted off with the pressure washer, and then the car was given another coat of the same mix snowfoam and whilst this was still on the car I washed it using AM bubbles which is a new product to me and must say I am really impressed as it gives the water a really slick feel to it which seems to help the mitt just glide across the car and has a cracking fruity smell which is slightly addictive. The car was washed using the 2 bucket method with grit guards in both buckets and a lambswool wash mitt.
The car was then rinsed off using a open ended hose and before the lower parts of the car and inner arch lips where sprayed with Tardis which was left to do its stuff before being wiped down with a microfibre cloth. The full car was then given a covering of Ironx
The car was clayed using citrus bling and water mix( 10 to 1) and a Bilt hamber soft clay bar which still helped pull lots of contaminates from the paint work it was then rewashed using the same method and dried using a Uber microfiber drying towel.
The car was taped up ready for a single stage polish using the Dodo Juice limeprime and 3m yellow pads
Uber drying towel
Valet pro tyre gel
AMDetails AMbubbles
Autosmart Tardis
3m Yellow pads
Noodle wash mitt
Snow foam gun
Autobrite Obsession
Ironx
Rainx
00 grade wirewool
