Third gear not going in smooth under hard acceleration
siruz Jan 30, 2007
  1. siruz
    siruz New Member
    Hello people. Im new to this forum. I got an S3 and under hard acceleration its not going in to 3rd gear smooth. Ive heard something about dong bone brace or something. Need some help if someone know cus i need to fix this its been anoying me for a while now.
    Sirus
  2. SteveS
    SteveS S6 avant
    691
    it might be the engine/transmission moving too much in the mounts, or linkage adjustment, try changing gearbox oil too. worst case its syncromesh or a selector shaft going in the gearbox.
  3. siruz
    siruz New Member
    Cheers mate. Ive heard alot about the bearbox moving about. It needs a service soon so i just need all the info i can get so i can go an do all the work in one go.
    cheers
  4. monkeytrousers
    monkeytrousers Member
    371
    This is a common problem on S3s I'm afraid. Crunch!
  5. Mo-S3
    Mo-S3 Member
    706
    The 6 speed gearboxes dont like to be rushed. Depends on what you define as quick gear changes. Like it has been mentioned before change the oil, check the gearbox mount to see if its tight. You can replace the gearbox mount aka dogbone with a harder one which will feel much better but be aware that you will feel more vibration through the car at idle.
    Does it still crunch when driving calmly?
  6. [Dave B]
    [Dave B] Daddy
    2,027
    145
    My bearbox moves when I run....
    Sorry couldn't resist it :)
  7. siruz
    siruz New Member
    Thanks for all the info people.
    It only crunches like im not putting the clutch diwn enough in third when driving hard. otherwise its all good.
    il check the mounts next week and see whats up.
  8. Stewart
    Stewart Member
    705
    10
    Thats exactly how I described the same problem, as if the clutch isnt engaging properly...
    Seeing as the parts are cheap I'm going to replace the slave cylinder and as a preventive measure I'm going to replace the clutch pedal and bushings which are prone to going as we've heard many times.
  9. Blunteh
    Blunteh Member
    196
    I've had this for 2 years... Then recently my fuel pump started to die (made a weird recyprical rubbing sound at the rear underside of the car) and has been replaced. As a pleasant side effect **drum roll** the crunch from 2nd to 3rd has completely gone ! I guess the fuel supply was backing off more aggressively than designed due to the fuel pump's problems and hence the timing for the synchromesh was out somehow...
    The fuel issue never threw anything up in VAGCOM etc.
  10. mattyboy199
    mattyboy199 Well-Known Member
    1,894
    30
    My 1st to 2nd gear crunch just dissapeared one day. However not so long ago it developed a 2nd to 3rd gear crunch. I m going to get the dog bone mount installed by Jabba, see how that fairs. Reading this post though my car is still on the original clutch (50k) so they could be linked.
    How much is a fuel pump ?
  11. Blunteh
    Blunteh Member
    196
    If I remember right, £150 with an hours labour....
    I used to find it was less crunchy after a servive too... Have had the linkages tweaked by Audi before which solved it for a couple of months...
  12. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,197
    2,013
    siruz....top avatar
    my gears are worse than a car I had with double the mileage (a vauxhall) but have maintained being the same noisy in the 25k I have done
  13. Perplexer
    Perplexer Member
    239
    1st and 2nd gear in my S3 have been a little crunchy since I had it almost 2 years ago. 2nd is the worst, it sometimes goes into 2nd in 2 stages if that makes sense. The wife manages to crunch 1st a lot when changing down into 1st approaching a juntion etc.
    Is this a problem, is something about to fail, or is it normal? Can it be fixed?
  14. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    some one on here must have cured this problem before?? i have put in some fully synthetic gear oil that really helped but still crunches into 2nd if you dont take care when changing im wondering if its the dogbone mount
  15. Defratos
    Defratos You’re Dethpicable!!
    2,232
    Dogbone mount helped me out a Little, I've got my gearbox oil just haven't changed it, I will hopefully this week and see if it helps with my crunching issues.
    Not too sure how good it is to crunch into 1st when approaching a junction, I wouldn't do that unless I was downshifting which I don't do down till 1st gear.
  16. h100vw
    h100vw Member
    218
    I would advise not going into first while rolling. It's not that great for the syncro. I always prefer to slip the clutch a bit in second. A clutch change is a fair bit cheaper than a gearbox rebuild.
    Gavin
  17. Perplexer
    Perplexer Member
    239
    I agree with the both of you.
    The wife is used to driving her Z3 which is much more forgiving on the gearbox/gear change than my S3.
    My question was more aimed at why second gear was being awkward.
  18. Jacko4130
    Jacko4130 Goodie Gum Drops
    848
    Mine use to do it when under stress but has cleared up these last few months and i've not touched it, oil level is fine and every thing is tight. Just a S3 thing by the look of it.
  19. TheSpaceCowboy
    TheSpaceCowboy Member
    520
    What part of the car is this?! Also top avatar as someone else mentioned :thumbsup:
  20. j4jon
    j4jon Member
    704
    I think he means dog bone mount. It is the engine stabilizer at bottom at the back. It controls how much th engine is allowed to rock forward and backward. The OE ones are fairly soft and can be uprated to stiffer ones. By using a stiffer one gearshifts can be more positive as the engine doesn't rock as much when coming off the throttle. The only downside is that you can sometime get more vibration in the cabin.
  21. TheSpaceCowboy
    520
    Ah I figured it was just couldnt stop laughing when I saw Dong Bone brace.
  22. tiger727272
    tiger727272 Member
    Ive got the same problem with my s3 everytime I accelerate hard from 2nd to 3rd "crunch" makes an awful noise.
  23. mattashforth
    mattashforth Member
    33
    i assumed my gearbox was fecked as it grinds from 2nd to 3rd under hard acceleration but after reading this decided to try a powerflex dog bone bush.best £16+vat iv spent,took 10mins to fit and grind has totaly gone nomatter how hard i drive and change gear!well worth doing if you have this problem!
  24. j4g3d
    j4g3d Member
    242
    I would say clutch is under so much pressure. Had a honda that did the same thing under hard accelleration. Eventually (after 6 months) Clutch went.
  25. adibose
    adibose RBN Tuning
    19
    Hi all, I have the same issue with mine S3, from second to third under hard acceleration is crunchy... it kills me :(
    I have changed the dogbone and the engine mounts as well with THS ones but the noise is still there.
    I have bought MOTUL performance gearbox oil and I will change it, I pray for the noise to go away....
    this issue is still on, living in almost every S3, TT or Cupra R...nobody has the right solution.
    I hope that there is not a syncromesh or worse... :(
    The wired thing is that when the engine is cold, or the gearbox oil is cold, no matter how hard I go from second to third there is no noise, no crunchy at all...and when the oil start to get high temperatures...the crunch appear! It might be related with the OIL? the EOM OIL is not performing well under high temperatures?
    any answer will be highly appreciated, even the topic died 2 years ago! :)
  26. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,266
    360
    How cheeky can you go with an avatar :)
  27. martin g
    martin g [censored]
    154
    I agree, Incredible when you think i got told off and told to remove something a lot less offensive really, hmmmm
  28. adibose
    adibose RBN Tuning
    19
    here we discuss about avatars ans stuff, but no about our car issues...
    cool :banghead:
    the thread became tits discussions :blahblah1:
  29. jonny87
    jonny87 Active Member
    1,094
    if its crunching when up to temp its probably down to tired gearbox oil, as you say not performing 100% when hot
    i changed my gbox oil a while back, i used redline lightweight shockproof oil from opie oils, think the idea is that it is fairly viscous even at full working temps so sticks to the gears more providing a 'cushion'
    since changing mine no gear change issues, although as said above the 6spd box doesnt like to be slapped around, treat it with kind and it will do the same for you :wub:
  30. adibose
    adibose RBN Tuning
    19
    thanks for reply. I got 2 liters of MOTUL Gear Competition, I shall change it these days to see if works, hopefully it will...
    Although I drive last weekend to the mountains , multiple S curves, almost 100 km on "S" curves, pretty much hard acceleration and deceleration, smooth gear changes but rev'ing from 3000 rpm to 6000 rpm and back continuously, and suddenly the gear crunch stops, absolutely not even the smallest crunchy...dunno why!
    I drive to home and after 2 days the crunch comes back :(
    It could be the position of the gearbox? it is not settled right? I have changed the dogbone with a more rigid one...
    I cannot imagine, why it stops after racing driving on the mountains...and now it came back.
    I will change the Oil and I will handle the shitty 6Sbox very gently.
    I love the car but the gearbox could be better :(
  31. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
    Yeah would be interested to know if a change of gearbox oil makes any difference.
  32. adibose
    adibose RBN Tuning
    19
    for some did, for some didn't ....
  33. jonny87
    1,094
    i know it did for me, thank good it wernt the synchro or anything more sinister than that
  34. drfeelgood
    drfeelgood Member
    225
    Lol yer mine has the same problem. Good to know its common lol
  35. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    Mine does it still.
    Had the car three years + now,
    In this time its had powerflex dogbone mount. New gear box oil... still here though
    I was now thinking either linkage or the sensor thingy that makes the car rev up slightly when you change gear??
    I did hear these can play up slightly,
  36. drfeelgood
    drfeelgood Member
    225
    There seems to be a knack to it, if you grab the stick from lower down, it wont crunch in as bad, however its slightly awkward changeing gears like that, i might take it in under warrenty next month and see if i can get some bits changed,
  37. ikbenben
    ikbenben Belgium S3 driver
    105
    Same problem here since a couple of weeks. Already changed the gearbox oil and added syncromesh additive.
    Also mounted a Powerflex dogbone bush. Nothing helped.
