third brake light on facelift s3
barters3 Aug 22, 2009
  1. barters3
    barters3 Member
    438
    Iv done a search but cant find what im looking for, i seem to remember that there was a diffrerence in changing the bulb(s) on the third brake light on facelifts and pre facelifts, ie one is a complete cluster and one has individual bulbs, just thought id ask before i go pulling all my boot trim out to have a look as only one of my bulbs havs gone.
  2. S3Steve
    S3Steve Active Member
    1,614
    17
    Facelift definately have individual bulbs as ive changed one in the past mate, cant comment on pre facelift though.
  3. Az
    Az Hard slammed!
    1,023
    34
    Yep, as Steve said mate, facelifts have individual bulbs. They are the small bulbs normally found in the back of instument clusters, but there are different sizes and wattages, so best to remove one of the bulbs and take it with you to Halfords rather than guessing.
  4. c_dog
    c_dog Member
    92
    how do you replace them? do you have to take all the boot trim off? I have one out and not sure if its worth the hassle just to replace the one!
  5. Az
    Az Hard slammed!
    1,023
    34
    When I bought my car it had 4 bulbs out, I managed to just pull back the trim far enough to expose the third brake light cluster and remove the 2 Phillips screws that hold it in. Then the individual bulbs simply pull out of the cluster!
    I was lucky enough to do it like that where I didn't have to remove any trim and it was a 2 minute job! :)
  6. c_dog
    c_dog Member
    92
    do you know what bulb type they are? cheers
  7. Az
    Az Hard slammed!
    1,023
    34
    Could tell you exactly what bulb you need mate which is why I said best to remove one of the bulbs and take it to Halfords or a motor factors with you to make sure you get the right one.
  8. Jimmybuckrogers
    Jimmybuckrogers Audi OCD VCDS Map User Audi A3
    136
    12
    They are 2.3 Watt Wedge/Dashboard/Panel bulbs. Halfords Part number: HBU284. Also seen them called R286 or 286X (make sure they are 2.3 Watt).
