thinking of turning my a4 to an s4 any thoughts tips...
ossipo77 Aug 19, 2011
  1. ossipo77
    ossipo77 New Member
    i have a 98 a4 quattro with a 2.8 v6 car has about 72k on it just redid the clutch with a excedy twin plate other than that car is completely stock how much can i pick the turbo kit for along with the intercooler ansd exhaust let me know???
  2. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,483
    Would it not be easier to just buy a similar age S4 and be done with it?
    Sarah's A3 likes this.
  3. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,699
    157
    Due to age of your car and price of a similar aged S4, financially, it would be cheaper to buy an S4. The 2.8 V6 Heads are N/A and S4 heads are forced induction. It's not just a simple 'whack a turbo, intercooler and exhaust on' job.
    If it's the challenge of doing a conversion that you're after, then go for it. but expect a bottomless pocket of money to chuck at it.
  4. aragorn
    18,036
    725
    Even if you were to convert the car, you'd really need the entire 2.7tt engine, and most of the front end of an S4.
    The heads and cams are different, the inlets different, the pistons are different, the pipes are all different, the wiring harness is different, lubrication and sump is different etc etc etc. Even the cooling system, radiators, fans etc are different
    I'd be looking at selling up and buying an S4.
