THINKING OF BUYING b7 CONVERVERTIBLE
sublime Feb 8, 2013
  1. sublime
    sublime Member
    33
    Hu Guys
    Im thinking of a buying a A4 1.8T (B7 budget is £7k)convertible and would like to know what to look out for as common faults?
    Also need help with the following:
    Is Manual better or Multitronic?
    Does the SLINE have better spec/trim or the Sport?
    Which model has multifunction steering wheel and Bose sound system? SLINE or Sport? or are these optional extras
    Does the standard sound system natively support MP3 or do I need one of these
    Venturi MINI multi-function Car Kit FM Transmitter: Amazon.co.uk: Electronics
    Any other tips/pointers would be most appreciated.
    thanks
    SS
  2. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,057
    9,076
    Welcome to audi-sport.net. Im sure one of the guys will be along shortly to help you out with some advise. Enjoy the forum. :) x
  3. hades-
    9,481
    646
    i dont like the multis autos etc thats something thats up to you
    bose etc is optional on se and s-line
    as are mfsw
    my s-line 07 came with mfsw dis thats it i retro fitted the rest the sport is more or less the same as s-line just older name
    only the RNS-E comes with mem card slots for the music
    everything you need can be retro fitted
    the sline has better seats 3 spoke wheel slightly lower and stiffer better bumpers
    the se is comfey so they say
  4. sublime
    sublime Member
    33
    bez
    thanks for the reply..
    sorry what is MFSW and RNS-E?
    i would go fr the manual although im the lazy driver :$
  5. hades-
    9,481
    646
    MFSW = multi function steering wheel
    RNS-E is the sat nav system that audi use it plays music through 2 sd cards cd and cd changer
  6. sublime
    sublime Member
    33
    great thanks..
    any common faults on these? leaky roof windows not shutting properly?
  7. hades-
    9,481
    646
    im on my 4th
    iv had an 03 03 08 now on the 07
    never had any leaks windows always close as they should
    you need to make sure its had the belts done water pump and good service history
    quite a few have the oil pick up pipe bung up and take the turbo and engine out
    CTS coolent temp sensor can go quite offen but a cheap easy repair
    other than that there good solid cars unless you get a bad 1
  8. sublime
    sublime Member
    33
    thanks bez
    will keep that in mind, how often should the cambelt water pump be changed? if one has been changed at say 51k and the car as 70k , is it prudent to get it changed as soon as I get it or can leave it for anther 10k?
    or if car has done 59k and nver had the belt replaced shud i get it replaced as soon as I get it?
