Thinking about an S3
Discussion in 'A3/S3/Sportback (8P Chassis)' started by madmike01uk, Jun 25, 2014.
  1. madmike01uk
    Offline
    madmike01uk Member
    Mar 7, 2013
    415
    20
    Anything to look for? Do they use oil like other TFSI engines? Looking at 07-08 plate around 50k miles. Need to drive one really, was looking at m3's but I think the s3 will be a more sensible cost effective car lol
    cheers
    mike
    #1
  2. Dan-Jnr
    Offline
    Dan-Jnr Active Member
    Jun 10, 2011
    779
    122
    No TFSi engine should use lots of oil, if they do then there is a problem.
    Don't think about getting an S3, just get one and you'll be pleased.
    They can be economical 30+mpg when cruising, 22mpg when booting it.
    Servicing and maintenance isn't too expensive, but if you start tuning it make sure you have a bit of change in the bank.
    #2
  3. S3Alex
    Online
    S3Alex Rarely neutral
    Dec 3, 2008
    5,607
    1,207
    Ok....lots of threads on this also but in short....
    FSH.
    Regular servicing and bills.
    Haldex service
    Coil packs and plugs may cause misfires.
    Most don't use much oil.
    Occasionally they do.
    Other than that very solid and reliable and can be modified to well over 500bhp if you feel that way inclined.
    #3
  4. madmike01uk
    Offline
    madmike01uk Member
    Mar 7, 2013
    415
    20
    It's quite well documented that the 200bhp TFsI engine can use a lot of oil, I'm guessing the S3 has uprated internals so was just checking to see if it had the same issues. Anything spec wise I should make sure it has? Will try and get a test ride this weekend and see what I think.
    How often are haldex services? I take it cambelts are 4 years or 60k?
    Mike
    #4
  5. Jtaylor
    Offline
    Jtaylor Member
    Apr 23, 2013
    60
    10
    They can be thirsty on oil mine takes a litre every 1500 miles both dealer and independent say its fine.
    #5
  6. S3 AEX
    Offline
    S3 AEX Active Member
    Jul 17, 2011
    249
    42
    Ye can be abit thirsty with the oil, my mates 1.8 tfsi was a hell of a lot thirstier than my s3.
    Just change the DV, PCV, if your getting 07-08 plate if they've not already been done I'm sure most will say the same!
    Check for oil round the rocker cover as well, some earlier models are known for a little leak round there (I think) could be thinking of summat else tho?! Someone will rectify if I am..
    #6
  7. madmike01uk
    Offline
    madmike01uk Member
    Mar 7, 2013
    415
    20
    thanks mate, there doesn't seem to be many inherent problems with them which is good. What's the DSG version like?
    #7
  8. Staz
    Offline
    Staz is a retronaut Staff Member Moderator
    Oct 26, 2006
    6,189
    47
    Holy ****! That's a lot.
    #8
  9. Jet2004uk
    Offline
    Jet2004uk Active Member
    Sep 26, 2013
    309
    43
    I am one of the lucky ones as mine hardly uses any oil :footy:
    #9
  10. Tom5190
    Offline
    Tom5190 Member
    Oct 16, 2013
    187
    61
    Jesus!
    I changed the oil in mine in November, and again in April I covered 10,000 miles and the level was pretty much exactly the same. May have used about 1/4 of a litre at the most.
    #10
  11. Dan-Jnr
    Offline
    Jun 10, 2011
    779
    122
    I must have a good engine as mine doesn't consume oil, gets changed during normal servicing.
    #11
  12. madmike01uk
    Offline
    madmike01uk Member
    Mar 7, 2013
    415
    20
  13. pluves1
    Offline
    pluves1 Active Member
    Dec 31, 2008
    366
    44
    That price doesn't look particularly cheap for a non Audi dealership.
    As S3Alex has pointed out the obvious things I'll add the less obvious!
    Check tyres are decent make and OEM spec. Someone on another thread has just purchased (or is about to) through the Audi Used Approved scheme and its fitted with budget tyres at £40 a corner that no one has heard of! If its been well looked after it should have Goodyears, Michelins or similar fitted that are 92Y speed rated and XL load.
    Check bodywork - ideally with a paint thickness gauge. Ideally you want to check under very bright light or failing that an LED torch can be used. You're looking for swirls and scratches. These are easily remedied by a good detailer for around £250 - so if it looks bad then you can use this as part of your negotiation.
    Carbon build up in the cylinder head is a known issue on this engine. Search threads to get an idea. Again it is easily remedied and can be cleaned but, cost is usually in excess of £100. Without taking the exhaust manifold off its hard to spot if your head needs cleaning but, on test drive try flooring it through the gears - any hesitation from the engine usually between first and second gear is a possible sign that it might need cleaning.
    Good luck with your search and as other have said these are great cars and easily maintained.
    #13
  14. madmike01uk
    Offline
    madmike01uk Member
    Mar 7, 2013
    415
    20
    thanks for the additional info, it seems inline with other on auto trader, I'll have a look on the audi site now and see if they have anything. The only thing I don't like about that car is the lack of reversing sensors although I'm sure they are easily added. I'd quite like the bucket seats but they seem quite rare......
    #14
  15. mechanic69
    Offline
    mechanic69 Active Member
    Mar 24, 2007
    484
    132
    Me 2, six months and not a drop used
    #15
  16. S3 AEX
    Offline
    Jul 17, 2011
    249
    42
    If your paying that price you really want all the extras.. Keep looking round you'll find one don't just jump in even tho the £££ are burning a whole in your pocket!
    #16
  17. mechanic69
    Offline
    Mar 24, 2007
    484
    132
    #17
  18. RPB
    Offline
    RPB Active Member
    Aug 28, 2011
    324
    43
    I've had to add 2.8 litres of oil into my car over its 27476 mile life! lol.
    yes I do keep a record ;)
    #18
  19. Jtaylor
    Offline
    Jtaylor Member
    Apr 23, 2013
    60
    10
    Hmmmm maybe I'm over estimating my oil consumption I will top it up tomorrow and reset the trip. Will report my findings.
    #19
