Thinking about a low mileage Audi 100 Avant 2.5TDI...
Vance Aug 4, 2005
  1. Vance
    Vance New Member
    12
    Hi everyone - first post...
    I used to own a 93 Audi 100 2.0E manual, of which I have fond memories...
    I'm now being severely tempted by a 1993 2.5 TDI. It has 68k miles on it (genuine,backed by old MoTs etc). It has been dry stored for the last 2 years, is in very good condition, and seems to run well.
    Firstly, what's it worth? It has no MoT, although I shouldn't think it'll have too many problems passing (and the current owner is happy to make the purchase subject to it passing).
    Secondly, what should I look out for? My list (so far) is to change the cam belt, fuel pump belt & alternator belt (quoted £385 by my local Audi dealer, but there's got to be a better value option than that!). I've had a play about with the handbrake and it seems to be functioning correctly (my last 100 - and the previous 80 - had problems with the handbrake cam inside the rear caliper wearing - if I remember correctly, you can get away with turning the cam around once, then it's down to replacing calipers to fix the problem).
    What else?
    The car isn't a Quattro, doesn't have air-con, leather or any of the desireable extras. It doesn't have a tow bar (which is good news - except it'll mean fitting one) - it has a load space liner thingy. Bodywork is red (non metallic) and upholstery black (Jacquard??) cloth.
    Tyres seem reasonable - mounted on 6 spoke alloys which are in pretty good condition (5 of them, too). Finally, the car is north of Aberdeen (although quite close to a mate's house, so that's not as big a snag as it might sound).
    Any advice very welcome - I've left a bid on it, but I think his expectation (borne out of placing a high premium on the mileage) is unrealistic - so we're staring each other out a the moment... /ubbthreads/images/graemlins/cool.gif
    Vance
  2. 28v6
    28v6 Guest
    Is this the 5 Cylinder engine?? If so your heading on the right path to get the cambelt changed, this was the same engine that was fitted to the T4 Transporter/Caravelle and caused some concern.. problems with overheating, oil pumps needing replaced etc etc... however like all cars if it has a wealth of reciepts to boot then you shouldn'y go far wrong with her, looks the part, make sure that the oil & Filter change is done regular and you'll be fine... Try Specialist Cars, Bavarian Auto Werke, and a chap opened up himself called Kevin located down on the harbour side where the "Nightlife" goes on apparently **wink**Wink** /ubbthreads/images/graemlins/wink.gif Supposed to be really good with VW/Audi.... /ubbthreads/images/graemlins/ok.gif
  3. Rev-head
    Rev-head Active Member
    2,987
    I agree with 28v6
    Price for the car with that mileage £1400-1600 ish
  4. Vance
    Vance New Member
    12
    Thanks for the advice. The engine is a 6 cylinder - the same as used by Volvo - married to a six-speed gearbox.
    Is the estimated value based on a car with an MoT - with the cost of a belt change to be added to it?
    Vance
    ps Kevin - how much would you want to fit new cam/fuel pump & alternator belts?
  5. Rev-head
    2,987
    ""Is the estimated value based on a car with an MoT - with the cost of a belt change to be added to it?""
    Yes to the MOT but not the belt change
  6. Vance
    Vance New Member
    12
    Ah well, he's put an MoT on it now, started driving it & has decided he doesn't want to sell it...
    Vance
