Things my A3 doesnt have
eddie_a3 Apr 15, 2010
  1. eddie_a3
    eddie_a3 Member
    30
    Ok, according to the user manual for the car
    the car should have/do things like:
    hill assist, so it holds the breaks on the hills
    and when you do an emergency stop the hazzards flash,
    are these settings that need enabling in vagcom or what?
  2. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,455
    593
    The hazzards yes but not sure how to do it - the hill hold I am not sure
  3. PH1L
    PH1L Gievf Buckets
    3,851
    40
    i thought the hazards were enabled as std it takes some sever braking to turn em on though
  4. h5djr
    9,438
    1,757
    How old is your A3. Hill hold used to be an option but is now fitted as standard to cars with S-tronic. Not sure about the hazard flashers with emergency breaking. I know it can be activated using VCDS but not sure if it comes set from new.
  5. eddie_a3
    eddie_a3 Member
    30
    its a 58 plate,
    so these cant be enabled by vagcom?
    if not what other cool things can be? ha!
  6. Pii
    Pii Member
    748
    Pretty sure there's a thread in the FAQ section with some details.
    Off the top of my head that I can think is are:
    - Auto door lock
    - All doors open when you click the key FOB unlock once
    - timings of coming home / leaving home lights
    - bleeps on lock/unlock
    - remove seat belt chime
    there must be lots more but I don't rememeber.
  7. h5djr
    9,438
    1,757
    You can do the hazard flashers with emergency braking with VCDS which incidentally is the new name for Vag-Com.
    This is the thread which tells you about some of the other things that can be done.....
    http://www.audi-sport.net/vb/showthread.php?79127-8P-VCDS-changes-thread
  8. eddie_a3
    eddie_a3 Member
    30
  9. N8
    17,163
    718
    There is a vcds section with a map of where the users are.
