Things I've learnt this weekend about the B6
AudiLeon Jan 28, 2012
  1. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,169
    148
    The steering pump is very easy to change on the 2.5 TDI. Just abit time consuming.
    Audi put steel bolts and parts into a ally upright and lets them corrode really hard together.
    So next thing I need to learn is how the hell to get the track rod ends out of my uprights.
    Edit: I also learnt that my car runs alot better with the maf actually connected to the car.
  2. Les 51
    Les 51 A pint of Diesel please!
    687
    Glad to hear you didn't have any problems! ;)
  3. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    47
    track rod ends need a good whack!
  4. AudiLeon
    2,169
    148
    The pinch bolts will not move in the slightest.
    They are corroded solid. So going to pop to audi get fresh bolts, drill these out and put fresh ones in.
    That's assuming you need the pinch bolt fully out in order to drop the track rod out?
  5. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    If its any thing like the B5s then yeah, you do.
    The pinch bolts are a right pain in the ass but like Turkster said.
    A good whacking and loads of penetrating oil should see you right.
  6. AudiLeon
    2,169
    148
    Tried that yesterday :( Got one hell of a copper hammer on it and it is stuck solid.
    Going to get some fresh track rod ends, some fresh pin bolts and my uber set of drill bits and take it out. They are truely truely welded in there.
    Ally and steel will corrode and pretty much weld tight.
  7. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    15
    Blowtorch - steel and aluminium expand at differently under heating and cooling.
  8. AudiLeon
    2,169
    148
    I put some pretty intense heat on it, whilst trying not to destroy the track rods. I'll get them out eventually.
  9. Ekco163
    Ekco163 New Member
    25
    If the head of the bolt has or can be cut or snapped off you could use the nut to wind out the bolt, and then drive out completely with a punch.
  10. AudiLeon
    2,169
    148
    I might be able to get a grinder on the head of the bolt. But it's not a normal bolt i don't think.
    Decent drill bit should get it out.
  11. swarcup
    swarcup Well-Known Member
    1,326
    40
    the pinch bolt is only threaded right at the end so the nut will not move it far enough to remove it. I did mine last summer and even with drill bits they are not easy (never again). If you arn't past the point of no return i would pop down to a garage and get them to change the bolts with a windy hammer then go home and do the job yourself.
  12. Turkster
    2,797
    47
    any updates ?
  13. Turkster
    2,797
    47
    also, when i did mine, we used them monkey grips on the rod and another set on the track rod ends and plenty of heat and force, they gave in at the end, was not a job i enjoyed or wished to do again, so i got the most expensive track rods ends you can get for the replacements.
  14. AudiLeon
    2,169
    148
    Nah no updates not planning on doing anything for a few weeks bud. The cars going lovely at the mo.
  15. Turkster
    2,797
    47
    i know that feeling, i too have a few niggles to fix but don't fancy doing them rolling around in the cold right now!
