Thermostat where is it located on 1.8T. ??
Bradderz_1988 Nov 27, 2011
  1. Bradderz_1988
    3,951
    235
    Basically as title as I think I've got the old thermostat stuck open fault as the temp gauge has a mind off it's own and my mpg has gone through the floor. And also get the 16500 DTC.
    A good write up or pic would be great.
    Cheers.
  2. aragorn
    18,296
    804
    Follow the bottom rad hose, it goes to a little plastic elbow, and the stat is under there.
    I find the best way to change it, is to first remove the hose from the elbow (i replaced the constant tension clamp with a jubilee as its less faff) then remove the elbow and stat.
    You then need to sort of balance the new stat and seal on the elbow, manoever it into position round a bit of block casting that sticks out, then bolt the housing up. Then refit the hose.
    Its much easier to refit it without the hose attached, hence removing it.
  3. Paradox1
    Paradox1 Active Member
    1,833
    88
    under the inlet manifold,but above the oil housing.
    I believe two screws holding it to the block.be sure to get a new rubber gasket aswell
  4. aragorn
    18,296
    804
    Not on an 058 block.
    On an 058 like the AJL Bradderz has, it has an external water pump and the stats mounted under that, right down the bottom beside the PAS pump.
  5. Bradderz_1988
    3,951
    235
    Cheers guys thought it might of been on back of the block as I'm doing the clutch conversion this weekend (if I get round to it) so was seeing of I could of done it a bit easier with the box out.
  6. aragorn
    18,296
    804
    Its not on the back of the block its on the waterpump housing.
    Drop the undertray off and look up on the passenger side, its right there.
    You got access to a lift to do the box?
  7. Bradderz_1988
    3,951
    235
    Yes got access to do the box as I work at Citroen so no problems with access or tools.
    I think I may now where it is is it held to the block with 2 10mm bolts just opposite/behind the water pump housing ???
  8. aragorn
    18,296
    804
    It doesnt attach to the block at all, it attaches to the underside of the waterpump housing itself. Sort of just behind the PAS pump.
  9. Bradderz_1988
    3,951
    235
    Kk I'm sure il find it lol
  10. aragorn
    18,296
    804
    just follow the hose, goes right to it.
  11. Bradderz_1988
    3,951
    235
    Is this the puppy on the bottom ???
  12. Broken Byzan
    13,237
    465
    inside that black plastic housing
  13. Bradderz_1988
    3,951
    235
    Cheers mate
