Thermostat & Temperature Sender - AGU Engine
WorkInProgress
Scotland
Evening all,
Would anyone possibly know the parts numbers for the following: -
Thermostat
Thermostat 'O' Ring
Temperature Sender
All for an AGU engined car
I'll need some coolant too, is it G12+ I would need? 3 litres suffice?
Any other little bits and bobs I should get? Dipstick holder?
I've got the non-moving temperature gauge issue so replacing the above and refilling with new coolant
Cheers,
Rob
dont know the part numbers but gsf or tps will stock the bits you need both quite local to you
