Thermostat S3 8L
millsy75 Jul 6, 2014
  1. millsy75
    millsy75 Active Member
    274
    Hello, apologies for my lack of technical knowledge.
    Having rods and hybrid etc etc done next week, should I be changing the thermostat along with the water pump or is it just changed as and when there is a problem?
    Thanks for the help.
  2. jasongtr
    jasongtr Active Member VCDS Map User
    441
    37
    as the head will be off i would imagine a cam belt and water pump is a standard to be done at the same time
  3. Joshstan
    Joshstan Member
    180
    17
    To be fair buddy a thermostat is around a tenner I would just get it done whilst everything is apart
  4. millsy75
    274
    Yes I have cambelt kit/water pump. I was wondering about the thermostat
  5. millsy75
    274
    So is the thermostat a pain to get to normally? I didn't think to buy one :-(
  6. jasongtr
    441
    37
    not really, its in a plastic outlet housing next to the ancillaries bracket (to the right of the alternator)
    millsy75 likes this.
  7. IrishDave
    IrishDave Active Member
    682
    45
    Easily replaced on a driveway. Takes about 10min.
  8. millsy75
    274
    Thanks guys, no need for me to be killing myself to get to TPS then before I drop the car off in the morning
  9. jasongtr
    441
    37
    only thing to consider is the loss of coolant when doing it, makes sense to do it whilst its all apart i guess
  10. millsy75
    274
    Yeah good point. Will see if my local TPS has one in stock in the morning. I may aswell replace it as I am doing with most things I can! Sump, oil pump, oil pickup pipe while the jobs being done!
  11. millsy75
    274
    I managed to get the thermostat this morning, it was around £25 from TPS
