thermostat replacement......help
cornish_a3_turbo Nov 22, 2008
  1. cornish_a3_turbo
    cornish_a3_turbo Guest
    hi all.
    i am
    loking to replace my thermostat on my agu 1.8t a3, i have the part...next thing is where does it go...and.....how!
    any photos or help is much appriciated...
    cheers!
  2. mattm
    mattm BLACK EDITION
    184
    look left of your dipstick tube, its on the left hand side of the block as you look at it. Good luck getting the screws off, Ive done 2 now and they're always a ******! :)
  3. LaSarthe&Back
    LaSarthe&Back Member
    300
    you will need a small universal joint to get to the drivers side bolt.
    Make sure you get a new o ring in the box.
  4. cornish_a3_turbo
    uni what!!??
    got some brown paper things in the box...im not mechanical minded :Flush:
  5. abdus
    abdus Top Gear VCDS Map User
    1,827
  6. abdus
    1,827
  7. cornish_a3_turbo
  8. LaSarthe&Back
    300
    It's really not that hard! And you can flush the engine while you're at it.
    Careful where you dangle the earh lead for the altenator! Mine slipped and blew a 110 Amp fuse!!
  9. cornish_a3_turbo
    cheers mate, but my friend is a full audi tech, so its ideal!
    plus its cold......
  10. abdus
    1,827
    well, if you have that kind of facility, why not use it :)
