thermostat help
Spatula Jan 31, 2013
  1. Spatula
    Spatula S3 8P
    257
    25
    Hello,
    I know this has probably been covered already, but I'm in need of help! I have just come to change my thermostat as it's knackered. So I followed a guide and got to the point where I remove the hose prior to thermostat. Engine coolant is now all over my garage floor. I expected some but not the lot. Is there any cut off to minimilise coolant loss? If not, where/how do I drain the coolant sufficiently? Is there somewhere near rad?
    Pleassseee helpp! :)
    Thank you.
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    There is a plug by the RAD, but it sounds like the damage has been done, there wont be much more coming out....:icon_thumright:
  3. Spatula
    Spatula S3 8P
    257
    25
    lol ok. I'll see how it goes.. I only got my t/belt and water pump done yesterday with fresh g12... which is now all over my garage floor :p.
    Well I'll try and bucket the rest out of my rad and put it back in..
  4. s3dave
    10,110
    736
    Hmmm it would have been a good shout to do the thermostat at the same time then...;)
  5. Pabl0
    Pabl0 Member
    140
    I got a lot more out once I'd removed the housing, so be warned and cover the dip stick tube ;-)
  6. Spatula
    Spatula S3 8P
    257
    25
    The housing came straight out with the clip that holds it on to the block.. I think it's already been snapped and shoved back in, so i'll buy a new one.
    I did ask the bloke to change it out when doing the w/pump and t/belt, but he just didn't bother.
    So I did it lastnight, it wasn't as hard as I thought to undo the bottom bolt, seeing as I had the tools. I think the hardest part was trying to put the butter fly clip back on to the hoses. I ended up using a jubilee clip..
    Also, the t/stat that I took out was completely snapped, i.e. the only part that was in there was the metal ring. No spring or cylinder.. I have no idea how/where that stuff has disappeared. Anyway I replaced it and now she sits at 90 perfectly ;-).
    Thanks for your help, and I'm sure i'll be back soon with more questions.
    - Spat
