Thermostat fitting guide
jiggaman Nov 14, 2009
  1. jiggaman
    jiggaman New Member
    Hi all. I've been searching he forums on here but cant seem to find a guide to changing a thermostat on a '96 a4 1.8t aeb. Can anyone point me in the right direction? Cheers.
  2. aragorn
    18,608
    871
    the stat sits in the housing that the bottom rad hose connects to on the engine.
    Its basically a case of slide undernearth, remove rad hose and housing, fit new stat, refit housing then rad hose, fill with coolant and bleed from the heater hose.
  3. jiggaman
    jiggaman New Member
    ah cool, sounds pretty easy, thanks aragorn.
