Thermostat and coolant temp sensor (G62) location on 2.0 petrol
Az Apr 8, 2013
  1. Az
    Az Hard slammed!
    1,023
    34
    Can anyone point me in the direction of both parts mentioned in the heading for a 2.0 NA B6 engine please? (can't remember engine code)
    Thanks in advance,
    Az
  2. Mike_B
    Mike_B Active Member
    533
    47
    Not sure if this helps much, but my Haynes says "On petrol engines, the thermostat is fitted to a distribution housing on the left hand side of the cylinder block, behind the coolant pump position" . Depending on the engine code, there seems to be varying degree of dismantling to get to it.
    The coolant temp sensor info is "On all models, an engine coolant temp sensor is located at the rear of the cylinder head, whilst on some engines, a second sensor is fitted to the radiator outlet pipe".
    Mike.
  3. Az
    Az Hard slammed!
    1,023
    34
    That's great, thanks very much for the info mate, I'll have a look out for those positions then. :)
  4. cookiesvw
    cookiesvw Member
    90
    I know this doesn't help but on my 1.8t I changed the temp sensor and it was one of the most fiddle and frustrating jobs I've had to do. I lowered my gfs tt at weekend and that felt easier.
  5. madmike01uk
    madmike01uk Member
    430
    21
    I'm doing mine on Saturday, did you take the y boost pipe out? I think this would make it easier
  6. CEC
    CEC Exhausted
    Hi Guy's,
    I have the same problem only mine is the 3.0 v6,Should I be looking in the same place ???
