The VW R32 suspension is the same that in S3 2008 8P?
santi wrx Mar 22, 2010
  1. santi wrx
    santi wrx New Member
    The Vw R32 suspension is the same that in S3 2008 8P?
    For my surprise Audi is not selling the S3 in the USA. I must get my suspension before a track day and I am on a hurry.
    What other car have the same suspension? I want to buy some coilovers.
    thanks
  2. santi wrx
    Is the same suspension of the audi a3 2.0T quattro?
  3. V6Pete
    V6Pete Now running on Bentley's y'all
    1,491
    Let's start again...... what model have you actually got?
  4. beanoir
    beanoir Large Member
    2,171
    31
    Surely the R32 nearly 100kg heavier has different suspension to an S3? I could be wrong, just fancied a guess as i'm bored..
  5. santi wrx
    Audi S3 quattro 2008
  6. V6Pete
    1,491
    Ok. Struts are the same, but the S3 will use lighter front springs.
  7. S3-Dan
    S3-Dan Quattro
    179
    but the point is they fit right ? theyl be a lttile stiffer but hes using it for a track day !
  8. NY_Sportback
    NY_Sportback Member
    58
    Definitely fit, I compare S-line springs to R32 off the car and they are the same height but the S-Line coil is a larger diameter (US spec R32 vs Euro Spec S-line)
  9. LWNY
    LWNY Member
    161
    Waddabout R32 vs Stateside Spec S-line? Are they going to be too low that I have to mind the sleeping policeman?
  10. V6Pete
    1,491
    Yes but springs are designed as sets. If the front is harder (and higher due to stiffness) than the rears, then it won't drive right.
  11. beanoir
    2,171
    31
    That was kind of my point Pete, would make the car handle a bit odd and screw the handling up a treat wouldn't it?
  12. V6Pete
    1,491
    Yeah it wouldn't be the best idea at all. The R32 / A3 3.2 has a considerably heavier engine, so will run different springs. He'd be better off buying regular 2.0T springs as these will be right for his weights.
