The unbreakable armrest button
Defratos Jun 3, 2006
  1. Defratos
    Defratos You’re Dethpicable!!
    2,232
    Right guys, here’s how to build the unbreakable armrest button:
    Firstly take out button from inside of armrest with No.8 Torx screw head.
    Once the button is out you will be able to see where the plastic bits have broken off. Simply drill two narrow (4mm) holes where the plastic broke off.
    Insert copper wire or anything metal really that’ll fit in place (I used copper screws) and glue it all together with some sort of adhesive.
    This has fixed one of the most annoying problems I have with all audi A3/S3s I've had and now I'm happy to say it SHOULD NEVER BLOODY happen again /ubbthreads/images/graemlins/froggie_red.gif
    P.S. Thanks to "NEiLS3LK51" for helping me get around this probelm, much appreciated mate /ubbthreads/images/graemlins/beerchug.gif
  2. NEiLS3LK51
    NEiLS3LK51 Member
    189
    No probs, mines been going well for a year now.
  3. Defratos
    2,232
    nice one Neil, Just one question. How come the metal threads underneath the armrest (from the rear ashtray) are still not alligned? what do they control and how can I align them up stright?
  4. treblesykes
    treblesykes Member
    690
    Thats the two handbrake cables, they will not sit straight due to differences in cables and each wheels brakes. no need to worry because the splitter plate shares the load evenly between cables when lever is lifted. Locknut in centre adjusts handbrake, give it a few turns if lever starts lifting too high.
  5. Defratos
    2,232
    sweet mate, cheers for that, would have taken me a while to figure it out /ubbthreads/images/graemlins/beerchug.gif
  6. sprout99
    sprout99 Member
    373
    mine has just broken. Can hear mechanism working but just not enough movement and button clicks
    how easy is it to get button out?
  7. Duber
    Duber Member
    135
    Is this to prevent the problem of the actual armrest dropping if you lean too hard on it? If so i'll being needing this in about a week.
  8. Defratos
    2,232
    no, not really. It's stops the armrest button from breaking (as it usually does) and hence creating the problem of the armrest locking in the "up" position. If it hasn't happened to u yet it'll happen at some point :beerchug:
  9. hamski
    hamski Member
    121
    Defratos... I see this as a nice little earner, if you're interested and have the time
  10. Defratos
    2,232
    interested in charging you for the job? lol is that what u mean by a nice lil earner? or r u relating to the money I have saved?
  11. sprout99
    sprout99 Member
    373
    i think he meant as a side line.
    Getting hold of 4mm diameter silver steel rods is easy and drilling through part easy too.
    Potential of approx 20 quid a repair is better than 170+ for armrest .....surely Audi to a button replace kit?
  12. hamski
    hamski Member
    121
    I meant you charging to do it for us thick, inept, lazy fools!! Well me, anyway
  13. Defratos
    2,232
    lol, sounds interesting but knowing me being a lazy bas**rd I probably won't get around to doing anything for a while. Plus it's very easy to do your self, just follow the simple instructions and it'll be over in no time. just get audi to take out the armrest, cause they're silly little buggers
  14. hamski
    hamski Member
    121
    Fair enough. I'll give it a go. Thanks clever guy
  15. S3DBW
    S3DBW Member
    180
    23
    Audi will supply a replacement button kit, from memory its about £18
    regards
  16. sprout99
    sprout99 Member
    373
    so they must know its a problem.....The hardest bit was locating the 4 screws which had been flocked.
  17. Duber
    Duber Member
    135
    While we're all on the Armrest topic. Does anyone have theres drop a click when weight is applied? and does anyone know why or how to repair it?
    When the armrest is moved it makes a rachet noise so i'm assuming that the rachet part is missing a tooth maybe creating it to drop slightly
  18. Defratos
    2,232
    Mine doesn't have that problem, so sorry can't help u there :unhappy:
  19. NEiLS3LK51
    NEiLS3LK51 Member
    189
    You can take the sides apart to dismantle the ratchet mechanisms on both sides but its not easy and requires plenty of patience.
  20. cocain
    cocain RAA RAA like a dungeon dragon!
    214
    Is it hard to take the whole armrest out of an A3 as I can't work it out?
  21. sprout99
    sprout99 Member
    373
    i had this problem. When fitting button you need to slide the tab on the armrest in between the two pegs on the button. fiddly but solves the problem.
    basically without this the button is pre-tensioning the armrest relaese
