The "S" button - coding question
Mr_Freeze Apr 19, 2013
  1. Mr_Freeze
    Mr_Freeze Well-Known Member
    389
    373
    Ok guys, this ones for you clever coding peeps.
    Is there any way you can recode the "S" button so that it defaults to on and then you have to press to turn off?
    I think i would prefer it that way round if it can be done.
    Also is the exhaust valve powered open or is it powered closed, just in case it can't be coded, wondered if there were any other ways of doing this?
  2. Macdaddy
    Macdaddy Active Member
    208
    92
    Simple answers no.
    On the R32's, TTRS etc there was a mod which involved removing the suction hose which opens the exhaust flap (actuator)
    May be possible to have the exhaust flap open all the time but when I was last under the car I don't think it's the same setup.... I'll double check
  3. klauster
    klauster Well-Known Member
    1,188
    112
    Doesn't it sharpen throttle response as well?
  4. robbiemac
    robbiemac 'S' Button engaged....
    733
    388
    ha ha ha.... before I even reach the end of my drive.......
    . push the 'S' button
    . push the traction to 'Sport
    . select 'S' in the DSG box (unless I've woke up + select manual)
    and off we go, great shout though; this set up should be default:icon_thumright:
  5. Macdaddy
    208
    92
    I thought so, All the vacum pipe removal will do is make the car sound like it does in 'S' but all the time.
  6. Macdaddy
    208
    92
    Right ive had a look under the car, Its the same as other VAG marques with the pump activated actuator.
    If you wish to have your car like its in Sport all the time just pull off the rubber pipe from the actuator valve and plug it with a screw, then cable tie it up out of the way.
    Mr_Freeze likes this.
  7. RYes3
    RYes3 Active Member Team Nardo Audi RS3
    919
    198
    43
    I have noticed that when on choke, the S button does nothing until it comes off choke. It then opens. I think it is forced closed so that would mean that if there were any timing/throttle response changes disconnection the pipe to leave it open may be a bad idea?
  8. P_G
    P_G Active Member
    383
    95
    Same thing happens on the RS4's, sport mode didn't open the exhaust flaps until after initial 30 second warm up phase. Those that disconnected / plugged their exhaust flaps didn't have any issues with the warm up phase by doing that.
  9. thesmileyone
    thesmileyone Active Member Audi A3
    510
    Its probably to stop people ragging it when cold.
