The Most annoying thing about my A3.....
C_Audiboy Sep 19, 2006
  1. C_Audiboy
    C_Audiboy Vroom Vroom
    822
    ..... is the fekin speed dependant volume on the Symphony unit!!!
    If I want to turn the volume up or down I'm capable of doing it myself!
    Anyone know how to turn this 'feature' off? Do I need VAG-com to do this?
    OK, I've started it off - now your turn!
  2. Eeef
    Eeef Lord of War
    1,607
    Do you have Bose? If you do, you're screwed.
    If you don't, there should be a GALA setting in the menu of the stereo where you can adjust the sensitivity of the volume adjustments.
  3. Vertigo1
    Vertigo1 Well-Known Member
    3,381
    542
    I have BOSE and still have the GALA setting
  4. mfspen
    mfspen Member
    577
    10
    Really ?
    How do you adjust the speed dependent volume ? I can't find any way to do this on my car.
  5. Vertigo1
    3,381
    542
    Bear in mind this is with a Concert II rather than Symphony but...
    Press and hold the Menu button until the screen changes to show "TP MEMO" (important to hold it until this happens)
    Now press the button briefly three more times to get to the GALA setting.
  6. C_Audiboy
    822
    Cheers, I'll try this.
    I have Bose BTW - I hope you are wrong Eeef!!!
  7. marriedblonde
    marriedblonde Active Member
    4,371
    Eeef's right - Bose doesn't give you the option to turn it off. Although I don't notice it on mine... Wonder if it's broken
  8. C_Audiboy
    822
    Na, tried it, no option to change this on my Symphony with Bose. Gutted :(
  9. garypaul
    garypaul Member
    51
    You do actually get used it eventually - took me about six months
  10. Vertigo1
    3,381
    542
    Well I definitely have it on my Concert II + BOSE so it's not specifically a BOSE thing. Either it's the Symphony unit which doesn't do it or the specific combination of Symphony + BOSE, although I can't imagine why.
    Anyone know if you can alter this setting with the RNS-E & BOSE?
  11. dmaudi
    dmaudi Member
    218
    yes there is a GALA setting on the RNS-E with BOSE
    set-up default is 3 but you can go 0-6 I think , I have it and BOSE but have left it alone as I did also get used to it from when I had my Symphony
    seems to only be the Symphony :shrug:
    Sorry to rub it in C_Audiboy
  12. Vertigo1
    3,381
    542
    Ah cool, as long as I can tweak it on the new motor.
    On my current Concert II + BOSE I have GALA set at 2
  13. rich1068
    rich1068 Member
    674
    The solution is to just play your stereo REALLY LOUD ALL THE TIME!!!!!! Then the Gala doesn't get a look in :)
  14. h5djr
    9,075
    1,496
    With an attitude like that you should be driving a Escort, Fiesta or a Corsa rather than an Audi A3.
