The Iridium BKR6EIX's
S3 Dave Aug 1, 2009
  1. S3 Dave
    S3 Dave Now running on Heavy Oil
    432
    Has anyone used these plugs?? They are cheaper than the Standard plug........ Any thoughts recommendations? Can't believe there is not a sticky for plugs. :)
  2. audiss3
    audiss3 New Member
    15
    i'd be interested in seeing what the recommendations for plugs are too. Should we just stick with OEM for S3's or is there another make(s) that members would recommend?
  3. LiveWire
    LiveWire S3X
    329
    I recently changed the plugs in my car, I bought a set of Bosche super 4's from halfrauds and when they were fitted my Idle was erratic, I called Halfrauds and told them the problem and they told me to bring them back and get a refund.
    So I orderd a set of iridiums and fitted them and the car then idled fine, I discussed this with my local VW specialist and they said bosche super 4's arnt good for turbo engine's (I cant understand why) and they also recomended the Iridiums...
    So I give these plugs the :thumbsup:
  4. audiss3
    audiss3 New Member
    15
    I have just gone onto the NGKFinders website and found the plug PFR6Q6458. Does anyone know if this is the same plug used at Audi main dealers as it seems to be about £15 cheaper for a set of 4 from ebay?
  5. fingermouse
    fingermouse thats me
    4,009
    I have those NGK PFR6Q6458 in my S3 seem ok to me :) got mine from GSF
  6. S3 Dave
    432
    Funnily enough i have been running Bosch super 4's for about 3 years without a problem. Just wanted to give these others a try. Supposed to be good for 100,000 miles. Always a varied response when it comes to plugs. :uhm::keule:
  7. LiveWire
    LiveWire S3X
    329
    I guess one of the plugs could have been "bad", from the factory..
  8. Keeno
    Keeno Spooly Spooly Boosty Boosty!
    701
    According to the Denso rep, they've never had a plug go wrong due to manufacturing error. (Apparantly all returned faulty plugd are sent back to japan for tests)
    Also, iridiums boast a power boost of 3-4 bhp in well tuned motors....
    ...good enough for me! :)
  9. banoffee
    banoffee Member
    124
    got them in mine too, from ebay (searched for PFR6Q)
  10. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    I am running the BKR6EIXs and they work very well. I was running Denso Iridium IK20s before that and when the engine got hot, the spark was getting blown out under full boost. This was due to the 1.1mm gap that the IK20 use. The BKR6EIX uses a 0.8mm gap which has eliminated my problem... THey work well
  11. banoffee
    banoffee Member
    124
  12. RichA3Turbo
    5,089
    Yep it is but some of the iridium plugs are larger which in theory should be fine, but when you get into higher output, it makes a bigger difference. i only foudn the cause of my problem looking at supra forums. Caused high RPM high boost misfires...was a pain in the ****!
