The first of many air con threads... I'm stumped.
benjie May 22, 2012
  1. benjie
    benjie Well-Known Member
    1,223
    305
    Have had a quick search and can't find anything that helps.
    My air con is playing up. Set at 21 today (26 degrees) and it went on full, then...
    Windscreen vent - ice cold
    Driver's vent (near headlight switch) - cool
    Central vent - Ambient
    Whatever setting I used (feet, top only, top and face etc) the temp stayed the same out of the vents.
    Then I set it to LO - no change.
    Then I set it back to 21... Lo and behold, the central/driver's vent then cooled down and became ice cold and it went on as normal.
    That's weird and I don't understand it.
    ECON light is not on, was re-gassed last August and no faults are showing in VCDS.
    Any ideas anyone?
  2. kite
    kite Member VCDS Map User
    677
    A stuck flap motor could be causing the fault.
    You can check their operation by dropping the glovebox and watching the flap arms move..
  3. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    use the output test in vcds to excercise it
  4. Ian-83
    Ian-83 Member
    202
    Carry out a basic settings.
  5. benjie
    1,223
    305
    Thanks for the suggestions, I'll align my flaps (ooh eer) in Basic Settings tomorrow and maybe have a look at the output tests, then if that doesn't resolve it, I'll have the glovebox off at the weekend and see what's going on... My friend owns a B7 so I'll see if I can take that apart and compare the 2 in operation to see if mine's not doing something it should!
  6. benjie
    1,223
    305
    Aligned the flaps via Basic Settings and gone through the output tests (all appeared normal) and it's still happening. Coding is all correct.
    I did notice that today, if I pressed the middle vents only button, the central vent eventually (after 2-3min) got cold. Then when I pressed AUTO, it stayed cold. So I'm thinking the central vent motor is on its way out?
  7. kite
    677
    You Could have a flap arm come loose.
    I would remove the glovebox and check the arms and their movement
