The ever-common power steering whine. but hear me out...
S3Jonny Mar 6, 2012
  1. S3Jonny
    S3Jonny New Member
    Firstly, i'm a newbie so hi and cheers for having a look. Finally got round to signing up the other day and i dont know whether to consider it good timing or whether i've jinxed myself by signing up but the day after my steering started whining it's tits off.
    I've been having a look around the forum and ive seen a few threads most of them talking about checking the fluid level, which i have and its ok. i also read one mentioning the power steering pump belt tension so i've figured this is where i'm going to start.
    i dont suppose anyone have any tips or advise on firstly where to find the tension belt as it's not too obvious from the top (not that i've really had a chance to have a proper look just yet) and also how i'd go about replacing it if it is the problem.
    Cheers in advance!
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I think you would be better jacking the car up and it is the bottom pulley closest to the front of the car on the left hand side (looking from the front of the car) it maybe leaking out of the metal pipes that run under the car... you can also check the fluid, it is next to the coolant top up bottle im guessing you have an s3 by your name, if so it will be under the cover with a driving symbol on it and a weird opening, i use a 50p piece... oh and welcome to the forum mate....:)
  3. S3Jonny
    S3Jonny New Member
    I'm going to hopefully get it in the air in the next couple of days, cheers for a starting point!
    Yeah i checked my power steering fluid level earlier, hoping that it would just be low so i could just top it up and be away but unfortunately it was bang on the max meaning it's going to be a bit more of an effort!
    Whats the best way to check if it's the pump or the belt etc?
  4. s3dave
    10,110
    736
    If the belt feels tight its unfortunately the pump, and to be honest if it is whining its gonna be the pump...
  5. S3Jonny
    S3Jonny New Member
    gah ok. are they easy to do, expensive etc?
    Sorry about all the questions! really appreciate it though [​IMG]
  6. s3dave
    10,110
    736
    They are not hard to do, 3 bolts ,,cant comment on price...
  7. aragorn
    18,600
    870
    Whining is usual cavitation, which can be caused by air in the system.
    Open the reservoir with the engine running, and see if the fluid looks frothy.
  8. S3Jonny
    S3Jonny New Member
    Ok cheers for the heads up. if it is, do i just work the steering with the cap off to bleed the air out?
  9. s3dave
    10,110
    736
    yeah full lock side to side a few times.....:icon_thumright:
