the clonkasaurus is back
newbster Feb 28, 2014
  1. newbster
    newbster Active Member
    302
    71
    it's back, not sure it ever went away, living somewhere in the front suspension, seems to be passenger side
    i changed top mounts and bearings about a month ago,i think it got better for a while.
    it seems to be at speeds below 25 mph, and i think i can feel a slight knock through steering wheel.
    i'll put her up on axle stands tomorow and have a poke around, likely suspects? in order
    bottom ball joint
    track rod end
    track rod inner joint
    arb bushes drop links
    have i missed anything?
  2. epox
    epox Active Member
    772
    74
    cv joint?
  3. hharry100
    hharry100 Member
    49
    Arb bushes are normally the most common cause, am in the process of getting some superpro bushes to replace my worn ones
  4. bentescort
    bentescort New Member
    My vote goes on the front dampers. Had a similar knock, changed loads of stuff then found the o/s/f damper rattling around in the strut body.
    Shaking the wheel it felt like the wheel bearing had gone so changed the bearings but it was still the same. Pair of new front struts sorted it, it drove fine but the front dampers were knackered.
    Ben.
  5. AJC
    AJC 3rd Gear
    181
    23
    passenger side - headlight levelling arm
  6. newbster
    302
    71
    thanks guys, i'll give those a prod tommorrow, excpet the headlamp leveling arm, don't have one of those :)
  7. Tooks
    Tooks Active Member
    753
    29
    In my experience, arb bushes, top mounts and arb drop links are common culprits.
    Doesn't mean it isn't something else though of course!
  8. newbster
    302
    71
    RESULT!
    ARB bushes and or drop links
    had a good poke around with the jemmy bar, nothing moving but the arb bushes did look worse for wear, but could not get any clonking noise when levering on them
    definelty not the track rods or ball joints, whcih i would have put money on it being, the noise was just like the last time i had to fit new ball joints
    so, decided to remove the bolt from the top of the drop link to the ARB and go for a (slow) drive
    quiet as a church mouse!
    so new ARB bushes and drop links
    any prefrence as to make, are power fllex any beter than oem for bushes
    i have plastic drop links at presrent, i recall a post about metal ones being better
    so, lesson here is don't make assumptions, and taking out the drop link bolt takes 5 minutes and pinpoints the source
    hopefully the clonkasaurus is back in hibernation.
    tooks and hharry win the ice cream mars bar first prize
  9. newbster
    302
    71
    great sucsess!!
    changged ARB nushed and drop links today, pretty easy spannering, would have been hard work to get the drop limk bottom bolts out wthout using a big impact wrench
    the noise was a definite meatllic clunk, which ii believe is the locating collar on the ARB hitting the subframe.
    this confused me, as on previous cars, the arb bush's made more of a muffled thud.
    next up is the dogbone
    thanks for all the advice telling me it was arb bushes :)
