The best discs to use with my brembo's?
S3 Paul Feb 5, 2014
  1. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    I've had a love hate relationship with the brakes on my S3
    its got brembo gt jnr brakes up front and 300 mm rear,
    I've been told a fair few times the lack of trust I have for them is down to my poor choice of discs and pads...
    So, looks like it will be ds 3000 pads but which discs? I don't REALY want to go 2 piece so it's...
    stock , ebc or brembo drilled?
    any other options?
    ive got about a month to source and fit them ... Mot looming
  2. Prawn
    11,639
    3,634
    Either EBC ultimax grooved, or Bills eliptically grooved Paul, although going on what you said you could source the EBC's for, that'll be the no brainer on this occasion.
    It's all about the pads though, I'm on DS3000's with totally stock ancient discs at the moment, and they really are staggeringly good.
  3. jojo
    28,993
    3,638
    Avoid the drilled discs Paul, they warp and crack, I did a pair in 500 miles I think? Ouch! I'm running Solid discs ATM with DS2500s with no issues, but my 2 piece discs should be with me by the end of the week! :cool:
  4. VAG-Slag
    VAG-Slag Well-Known Member
    1,771
    409
    If it's a daily car I personally would avoid ds3000... They get through discs as quickly as pads (if not quicker), they're noisy as **** and you can look forward to scraping metal/carbon deposits off your car/wheels every weekend. Not worth the ball ache IMO
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I think the ds series eats discs at an alarming rate and burn your alloys, and you are not a track guy..
    Are you sure all your pistons are working freely in the brembos? 1 of mine had seized in both sides (rear)and like you wasnt too impressed with them, i have gone for the focus rs pads this time + ultimax discs, but cannot comment on them yet..
  6. S3 Paul
    2,825
    107
    Im alarmingly hard on my brakes.
    I am the same in my golf but that is a fraction of the weight of the S3.
    As for the Metalic dust from using the DS pads... if they are washed on a weekend and using iron x to lift the deposits will i not be ok?
    Mr Prawn, I only posted this on here as i feel bad hounding you ,
    I have been offered EBC ultimax discs for £112.50+vat and the USR ones for £157 + vat
    Im sure i paid about £100 for a pair of standard disc before??
  7. <tuffty/>
    21,786
    4,170
    If you are hard on brakes then DS2500's are a min spec IMO... std pads are a fairly one use affair if you are a spirited driver...
    I am (for my sins) running pagid pads on mine currently as I need to replace both rotors and pads (gonna do it altogether) and even with 330mm 2-piece discs and ATE blue fluid the pads are just dead after one heavy stop and take a few gentle ones to resurface them enough to get rid of the judder and have some bite back..
    I am not heavy on brakes personally so the set up suits my current needs but I'll be on 335mm rotors and DS2500's once the cars on the road
  8. VAG-Slag
    1,771
    409
    I went cheap and just stuck on some Delphi discs (330mm) and the OEM brembo pads this time round... Overall I've been very impressed with the brembo pad as I wasn't really expecting much to be honest, my only complaint would be that they seemed to take a good while to bed in properly. But for a snip above 50 quid you really can't grumble!
  9. S3 Paul
    2,825
    107
    330mm?
    What are they for ? with stock LCR style brembos?
    Are these the Alfa brera discs?
    Is It a worth while upgrade?
    Im guessing i would need to space the caliper out slightly?
  10. Prawn
    11,639
    3,634
    if you match the offsets you can use 330's yes Paul, but typically they need the PCD re-drilling. I'm not sure how the brera discs compare to LCR offset wise.
    Radially, you can just space the caliper 3.5mm to suti a 330 disc.
    Ds2500's, as you know, will be no use for you.
    in this instance, Pauls requirement is above and beyond the norm, so most peoples experiences will be sadly meaningless.
    Paul is mullering DS2500's for breakfast, much like I would if I were ever to use them again.
    Ds3000 or similar required in this case.
    S3 Paul likes this.
  11. S3 Paul
    2,825
    107
    So as we discussed... get the ebc discs 323mm and ds3000 pads?
    full flush with ATE super blue fluid?
  12. IrishDave
    IrishDave Active Member
    682
    45
  13. Prawn
    11,639
    3,634
    I had the more expensive Godspeed 2 piece 330mm setup.
    Utter Shyte.
  14. Munch
    Munch Member
    256
    23
    Glad i saw this, was just about to as the same thing for my lcr brembos. Only running standard agu power at the moment, but heard different things about different brands of discs and pads
  15. Prawn
    11,639
    3,634
    if funds are tight, don't get half decent discs and pads. Get stock discs, and spend all the money on the pads.
    <tuffty/> likes this.
  16. Gops
    3,198
    666
    I've got stock discs with 2500's. Going for 3000's next!
  17. lol4fun
    lol4fun Member
    190
    Brembo max disks look pretty decent and someone on here recommended them over ebc
  18. IrishDave
    682
    45
    @ Prawn.
    What problems did you have with the godspeed disks. So far I can't fault them.
  19. s3dave
    10,110
    736
    You can use the gearbox to slow you down you know, cant understand people who say they smoke their brakes on the road...;)
    superkarl likes this.
  20. superkarl
    superkarl MAN OF STEEL
    9,593
    2,474
    I engine brake farrrr too much, because of how **** my brakes are
  21. S3 Paul
    2,825
    107
    Its driving style ... spirited driving kills mine
    i know of 2 places i dare not try and stop from speed.
    That to me ( when people still go wow... look he has Brembo's it must be quick) this is dangerous,
  22. david7m
    david7m Active Member
    551
    44
    Are they really £180 for front pads only?
    Dave
  23. Prawn
    11,639
    3,634
    They were absolutely shot to pieces in less than half a day in the wet at Spa.
    I faced them, and tried again at Combe the next weekend, and they didn't even last a full session before developing serious judder.
    The single piece ones may well be better, but the 2 piece are a joke.
  24. badger5
    9,577
    2,039
    jurid aslo 323x28, £75/disk+vat
  25. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,902
    2,703
    @s3paul , @Prawn thanks for your comments on this thread will cross the Godspeed 330mm discs off my list of possibles.
  26. NickVC
    NickVC Member
    35
    imo, if ds2500 arent good enough for street use, then you should look at cooling youre brakes instead of upgrading to bigger/better/more expensive parts.
    Did a fair amount of trackdays with brembo stock/ ds2500 but with proper brake cooling and never had any problem with them...
