The amazing spoiler thread
heeman10 Jan 19, 2011
  1. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,216
    305
  2. owenjt
    owenjt Member
    118
    Messaged them and they replied it's 'the Sline version'.
  3. FranA3
    7,216
    305
    the car in the picture has got the votex bodykit on it lol
  4. Ads
    Ads License to drive
    8,230
    607
    This is 100000% NOT an s-line/S3 spoiler.
    It is a Votex spoiler.
    Here is a photo of my s-line/S3 spoiler that is awaiting fitting, and you can see the part no. is 8P3 860 943:
    And here is the label from a Votex spoiler, showing part no. 8P0 071 640 K (the same one as on ebay) :
    And here is a link to Stoke Audi's site selling a Votex spoiler, showing the same part number, which they state is not for the S-line, RS, or S models: ----->> Audi A3 Roof Spoiler - Stoke Audi Parts
  5. josiah2007
    josiah2007 Coasting
    64
    Good research my fine fellow!! :thumbsup:
  6. Ads
    8,230
    607
    My s-line/S3 spoiler (part number 8P3 860 943):
  7. Ash187
    7,452
    713
    S3 spoiler fitted onto my 05 Sportback Sport model... £100 from a scrapy, cut off 2 side lugs, kept middle one and fitted onto car with glue...
  8. owenjt
    owenjt Member
    118
    Finally got an s-line spoiler and taken it to be sprayed today. How do you attach it? Assuming just use some strong double-sided tape and some special glue/bonding adhesive?
  9. owenjt
    owenjt Member
    118
    Anyone?
  10. Ads
    8,230
    607
    You'll need to chop off the fixing lugs first, if your car isn't an s-line/S3.
    Then you can either use a strong double sided tape or something like sikaflex.
    There are pros and cons to both:
    Double sided tape causes the spoiler to not sit as flush as it could, but if you ever need to remove the spoiler you can do so without damage.
    Using a bonding adhesive will mean that the spoiler will sit totally flush with your roof but you probably won't be able to remove it without damaging the spoiler and your paintwork.
  11. Ash187
    7,452
    713
    It depends if your is a 3 or 5 door. as i am pretty sure the 2 have different 3rd brake lights.
    on my 5 door i took the existing brake light off by unscrewing it from underneath (inside the rear hatch) and that left me with a whole to put the middle lug into. i cut off the other 2 lugs n either end of the spoiler and then used sikaflex on the spoiler to bond it and then used masking tape on the spoiler to hold it in place for 24 hours.
    here is an earlier thread when i originally fitted mine.
    http://www.audi-sport.net/vb/new-a3...ort-what-spoiler-fit-s3-alloys-sportback.html
  12. owenjt
    owenjt Member
    118
    It's a 3 door. I chopped off the lugs before I gave it to the painters. It had double sided tape already so I assumed this was how it was fixed, would prefer it to sit flush and have no intention of taking it off so maybe just get them to use bonding adhesive then.
  13. jsosic
    jsosic Member
    203
    So this part number that Audi sells as aftermarket roof spoiler is votex spoiler? Damn...
  14. Breezey
    Breezey Member
    453
    Are you guys bonding straight onto the existing spoiler bit (i.e the flat bit that comes on sport models etc) or do you take that off first then add the S-Line spoiler?
  15. Ash187
    7,452
    713
    3 door or 5 door? 3 door bonds straight on... 5 door needs the 3rd brake light to be removed
  16. Breezey
    Breezey Member
    453
    3 door, had a read through the thread does the light not need to come out first? to connect to the light in the sline spoiler?
  17. Ash187
    7,452
    713
    maybe i have forgotten but i could have sworn the 3 doors just fit on top of the existing brake light with a cut out?
  18. Breezey
    Breezey Member
    453
    Sounds like your describing the Votex one ? swear the S3 / Sline one was a new brakelight if your retrofitting to a sport etc?
  19. Ash187
    7,452
    713
  20. Breezey
    Breezey Member
    453
