The A3/S3 LED Bulb "how to" Guide!
tobycruse Nov 21, 2008
  1. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,664
    118
    Ok, I have my numberplate LED's fitted now.
    I went ahead and bought the metal LED's in white and so the resistor couldnt get too close to the LED I got mini-resistors.
    The hardest bit was getting that flipping screw out.
    With the LED and resistor in place (before soldering)
    Left: Original bulb, Right: LED bulb
    Thanks again for the guide, will start on the interior soon!
  2. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,325
    188
    Cant understand why anyone would want to brighten up their numberplate lights !!! As dim as poss for me, better still....take the bulbs out...
    Will you be fitting a back light to your tax disc as well :)
  3. N8
    17,163
    718
    Not that Pat, just to get rid of the horrible yellow....
  4. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    I don't think those resistors are going to last too long! They're probably 0.3 watts. You need 2W resistors really.
    I bought those same LED bulbs from world-sound on eBay. I went to fit them and one didn't work. I emailed them and they sent another out and by the time they arrived either the new one or the one that DID work stopped working so out of the 3 I have 2 that don't work. Waste of time.
  5. N8
    17,163
    718
    My led reg plate lights are perfect, and they have built in resistors I think :icon_thumright:
  6. Staz
    6,206
    67
    Which ones have you got? Ryans look great so I'm hoping he can remember where he got them.
  7. ryanstewart9
    ryanstewart9 Member
    494
    Anyone found out if the Bimmian led's work or not?
  8. ryanstewart9
    ryanstewart9 Member
    494
  9. N8
    17,163
    718
    HERE are mine. Perfect for me.
  10. fizz
    fizz Member
    264
    Do you know if these are similar to the ones on the new BMWs?
  11. jb0o
    2,664
    118
    I asked the guy at Maplins and he said he did the same to his car, and the mini's are still working for him - time will tell I guess..
    I got the LEDs off eBay from the seller cederson. When I first tested mine they both didn't work and I was gutted... then I turned them round, lol.
  12. N8
    17,163
    718
    No better, they are too bluey.
    BMW's = :motz:
  13. fizz
    fizz Member
    264
    Phew :) getting them ordered then
  14. N8
    17,163
    718
    Nice one Fizz, let me know your thoughts, mine are PERFECT. Love them :wub:
  15. fizz
    fizz Member
    264
    That site wants £7.99 to deliver 2 small bulbs, did you pay that? :motz:
  16. N8
    17,163
    718
    Yeh £20 delivered. What can you do, worth it man, £10 per bulb for perfect look.
  17. fizz
    fizz Member
    264
    just ordered them, will let you know how I get on mate
  18. Vex
    Vex Member
    67
    hi, I have read your "how-to" guide but I have a problem with my nuber plate lights I bought the 36mm festoon smd LED's and put the 2w 180 Ohm, they were working a day, then I used the 150 Ohm and they blinked and turned off, can anybody help me?
  19. jb0o
    2,664
    118
    Just to let everyone know I've driven 1000 miles on my mini-resistors, mostly in the dark without one problem yet :) *touch wood*
  20. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    I've Just taken down my back rear interior Lights and it's not the same as tobycruse Back Interior light. They look like the picture below... Can Anybody Tell me What LED Bulbs I need for this Lighting ?
  21. fizz
    fizz Member
    264
    Same as the ones in the front mate, festoon rather than the map reading type
  22. Brian566
    Brian566 Member
    70
    Thank for the Info I have just fitted hight output red Led to footwell light I used a feston bulb as could not get wedge to fit had to solder in and modify but suspected it a resisor issue as worked ok on first one but now both done only stops on a minute
    And this post saved hours messing about with values
    Trip ddown to Maplins
  23. ST09
    ST09 Member
    319
    17
    which led bulb do i need for glovebox light ???
    Sal
  24. khalil
    khalil Member
    774
    is there a link for a person whos selling all of the follwing
    main light
    map light
    rear interor light
    glove box
    boot light,
  25. khalil
    khalil Member
    774
  26. vw754
    vw754 vorsprung Durch Technik
    2,345
    58
    i want change number plate bulbs in my a3 sportback tdi 2006/// can anyone tell me what size they are ?
  27. mdre83
    mdre83 Member
    634
    Just done the LED conversion today with cracking results... although I'm assuming more than 5 resistors is needed as I've got a very dim glow coming from the front main lights (not map reading ones) only when the ignition is on and the button is set to the middle.
    I've put a resistor in passanger/driver footwell, one in each number late light which would only leave me with one for the boot. Yet to do the puddle lights.
    Rear map lights seem to be ok without resistors, no dim glow...only from front main. Would a resistor sort this out?
    These are the only pics I have at the moment taken with phone as camera is goosed!
    I'll upload some better ones when I have them.
    Also no error on DIS from anywhere...tocuh wood. :icon_thumright:
  28. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    Looks good mate! Face lift tail lights would finish that rear off nicely! :sorry:
  29. mdre83
    mdre83 Member
    634
    :motz: :p
  30. mdre83
    mdre83 Member
    634
    I've just added a resistor to the rear map lights as shown within initial post.
    Plugged the rear unit back in and it blow fuse 15 (interior Lighting)
    Any idea why this would happen, a bit reluctant now to add the resistor back in to prevent the dim glow incase the fuse blows again. :sadlike:
    Blue line shows the break...
    Glove box is also done, no resistors needed here... I have no error on DIS.
  31. mdre83
    mdre83 Member
    634
    Anyone?
    Also can't get the boot light one working...
  32. mdre83
    mdre83 Member
    634
    Bump, no one got any ideas?
  33. T-Bag
    T-Bag New Member
    same prob as above
    brought some 501 w/ resistors for the glove box and the boot - the original blubs for both boot and glove box were the same model etc however the 501's i purchased, the glove box fits fine and the light works perfectly - the same 501's doesn't work for the boot, tried both ways and nothing happens ...any ideas? or am i using the wrong model?
    its for a3 - 3door - 56 plate
  34. vw754
    2,345
    58
    should be the same.......try it without resistor
  35. mdre83
    mdre83 Member
    634
    I have my rear map lights in, without a resistor and the front main ceiling lights have a dim glow... ?
    Adding a resistor to the rear maps lights blows the fuse...?
  36. T-Bag
    T-Bag New Member
    there build in resistors.
  37. L80EWY
    L80EWY Active Member
    393
    45
    What size are the festoon bulbs in the back on the ceiling? sorry if its been mentioned
  38. r3stu
    r3stu Member
    111
    Anyone know if the rear ceiling bulbs are the same size as the front?
  39. vw754
    2,345
    58
    front are 42mm and rear 36mm (same as number plate ones)
  40. 330_2_S3
    330_2_S3 Member
    243
    Sorry to dig up this thread, but how do you fix this "dim light" problem?
    I have changed out the rear map lights and the numberplates with no problem.....The front mains are still yellow and the 42mm LED's are on order.....
    Just want to be prepared for when they arrive so I know what to do to fix it?
