The A3/S3 LED Bulb "how to" Guide!
tobycruse Nov 21, 2008
  1. Jamiekip
    Jamiekip Member
    717
    You should try PM'ing Marc in here:
    http://www.vagoc.co.uk/vb/forumdisplay.php?f=14
    :thumbsup:
  2. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    I have done the puddle ones, as above, didn't have any problems with them. also didn't have to bend any contacts.
    What problems are you having?
  3. mac1403
    mac1403 Member
    972
    Staz. Where did you get the refractor led's from. The puddle lights are narrower than the footwell lights so when I try to fit the refractor wedge they will not fit properly as the contacts are shaped to hold the standard wedge festoon. The other problem I have is when I try to replace the boot bulb with an led it will not light at all. Fitted a 150 Ohm resistor and it comes on flickers and goes off again. Also tried it with a 220 Ohm resistor and it was the same. Should I have fitted the led's in the puddle lights first? as the above problem is with the puddle lights standard and trying to fit the boot led first.
  4. Staz
    6,206
    67
    I got all the bulbs via the links Toby posted above. I used the same flank bulbs for the footwells as I did for the puddle lights. Exactly like these. I used 2x 220Ω resistors, one in each side.
    The boot light and footwells are on different circuits so they won't affect each other.
    I haven't done the boot light as I didn't see the point but as the combined resistance for the 2 footwell LEDs is 108Ω I would try a 100/110Ω on it's own for the boot mate.
  5. mac1403
    mac1403 Member
    972
    Thanks mate. Thats shed a bit of light on the matter. I will order some of the leds you mentioned. I have been using the ones with the 4 leds spaced around and 1 on the end. They are too wide for the bulb holder which is why I have been having problems. Do you get good enough light out of them for the puddle lights?
  6. Staz
    6,206
    67
    Aha no these ones are just a bit of 1mm board with the LED soldered on, fit in nicely!
    The light from them isn't more than the bulbs they replace, it's just white. They don't need to be any brighter anyway!
  7. Scott
    Scott Well-Known Member
    1,306
    126
    Excellent tutorial thanks. I'll give this a go for the rear number plate bulbs as I have really wanted to do this for a while. Does anyone know if 37mm bulbs will fit? I always order LED bulbs from www.ultraleds.com as I have had problems with cheap LED bulbs off eBay.
  8. Staz
    6,206
    67
    37s will fit no problems mate.
  9. Scott
    1,306
    126
    Thanks mate, I'll let you know how I get on. I may attempt some others in the future too!
  10. martyboy
    martyboy Member
    532
    20
    excuse my ignorance, but i see you have to solder only one 150 ohm resistor in parallel for the rear interior lights when replacing with led bulbs, but what about the front festoon light?
    mine is the basic one with only the one main light,
    so do i need to solder a 150 ohm resistor in parallel with one bulb, two bulbs or no resistors?
    cheers
  11. N8
    17,163
    720
    I really need to do this mod!
  12. mac1403
    mac1403 Member
    972
    If you don't have the map reading lights and just have the main light you shouldn't require any resistors. The only reason you have to fit resistors in the rear map lights is to prevent them staying on dim when you are driving. The only other resistor is required for the footwell lights as they will only stay on for 5 seconds if you don't fit one
  13. martyboy
    martyboy Member
    532
    20
    thanks for clearing that up matey!
    wasnt sure after reading about the issues with 'bulb-out' warnings on the DIS
    as the led's dont draw as much current as the old bulbs. i thought resistors had to be added to all the led replacements for this reason!
    cheers :icon_thumright:
  14. Staz
    6,206
    67
    I didn't fit a resistor for the map reading lights by the way and don't have the dim bulb problem.
  15. martyboy
    martyboy Member
    532
    20
    and i assume no bulb-out warnings either on the DIS?
  16. Staz
    6,206
    67
    No mate. Or errors with VCDS.
  17. martyboy
    martyboy Member
    532
    20
    fitted my leds to the front and rear interior lights today, and no probs with rear lights staying on dim or bulb out warnings on the dis! so all in all pretty chuffed! :)
    now does anyone know if changing the glove box light is just as easy, old bulb out, new led bulb in!!!
  18. gixxer600k4
    gixxer600k4 Member
    692
    it should be like that with every bulb in car, obviously you may need to wire up some resistors, but should be fine! i think the glove box and boot light are the same bulbs you have in ur side lights
  19. Staz
    6,206
    67
    Someone was asking about this the other day, they thought the glove box was on the same circuit as something else as they were getting a warning. I can't remember who or where though!
    There's only one way to find out for sure though.....!
  20. mac1403
    mac1403 Member
    972
    That was me mate. Wasn't the glove box, it was the boot though. I thought the boot and door puddle lights were on the same circuit. Have now done all the lights with led's except the boot. Only actually used one resistor and that was for the footwell lights (150Ω in one side)
  21. Staz
    6,206
    67
    Aha yes! Sorry I forgot.
    So you don't need one in the glove box then? And is it the same as a sidelight bulb?
  22. martyboy
    martyboy Member
    532
    20
    if it is the same, what are the sidelight bulbs?
  23. Staz
    6,206
    67
    Normal 5W5s mate:
  24. martyboy
    martyboy Member
    532
    20
    could someone clear this up please, do the resistors need to be in parallel or series?
    ive just been told of some smart **** at work they need to be in series, but i thought parallel? :confused:
  25. Staz
    6,206
    67
    Parallel mate! If you put them in series the voltage would be dropped across the resistor and not the LED.
  26. martyboy
    martyboy Member
    532
    20
    thanks for clearing that up matey! :icon_thumright:
    its not often im wrong, but im right again!!! :)
  27. Staz
    6,206
    67
    It's not the first time I've had to help out one of your kind with some basic electrics :p
  28. martyboy
    martyboy Member
    532
    20
    electrics? what are they? :confused:
    here is what this guy is quoting, help me prove him wrong, PLEASE?
    "Every commercial led light made has a current limiting resistor. To figure yours add the forward voltage, subtract from 12 (for 12 v system) and divide by .02 (20ma). This is simple Ohms law. For 3 super-bright leds there is a 10.2 forward voltage drop (series wiring). So 1.8/.02 gives a resistor of 90 ohms. For 13.8 volt supply a 3.6/.02=180 ohms. Super-flux leds are slightly higher voltage so 3.6(typical) is used for each led. For 2 on a 9v battery it is 1.8/.02=90 ohms. If you don't have the exact value, always go to the next higher fixed resistor. This will work fine w 100 ohm resistor or even higher, and gives a small margin for safety. For questions consult ohms law............."
    he is a tosser by the way!!!
  29. Staz
    6,206
    67
    Easy to prove him wrong... the LEDs we're talking about already have the resistors built into the circuit to enable them to work with an input voltage of 12v.
    All we're trying to do with the parallel resistor is fool the car into thinking there's a normal bulb there as the current draw on the LEDs isn't enough and the car things the bulb has blown. It then kills the power to the LED.
    For questions consult STFU law.......
  30. mac1403
    mac1403 Member
    972
    OMG.....Does he do the vulcan salute and speak Klingon. I hate pointy headed people LOL
  31. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,488
    Being somewhat indolent, and lacking in technical capability, can I (at any cost) buy a PIAA extreme white bulb that will look like the OEM ones, but deliver the super white light (OK, so not LED white).
    I can't be @r$ed with soldering resistors and all that malarky despite it looking VERY trick.
    Been searching t'internet and found some smoked festoon bulbs (12v 5w 42mm 264 type), but not upgrade ultrabright ones.
    Also, does anyone have a part number for the reading lights in the overhead festoon? I was hoping they were going to be like the w5w's that go in the side lights (as I have a spare set of PIAA extreme's sat in the garage), but they're not :sadlike:
  32. brissett
    brissett Member
    41
    "All we're trying to do with the parallel resistor is fool the car into thinking there's a normal bulb there as the current draw on the LEDs isn't enough and the car things the bulb has blown. It then kills the power to the LED.
    For questions consult STFU law......."
    Epic
  33. brissett
    brissett Member
    41
    If i didn't opt for the interior lighting extra for my car, will i still be able to do this modification? I understand that the puddle and footwell lights won't be there (is this correct?) but does that mean that the bulbs won't be fitted? or that i would have to cut holes and buy the light cases as well.
    Cheers for the help:sos:
  34. Staz
    6,206
    67
    There's some info in the FAQs thread about interior lights retrofit.
  35. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    What a nightmare this all seems!
    I have done this in my BM, and all I had to do was fit resistors to the numberplate lights, the interior ones worked without fault or resistors.
    I mean who need bulb failure warnings on an interior bulb FFS? You can see when its blown just as easily as you can see the warning notification, in fact you'd know as soon as you opened the door, before the ignition was even on, talk about over engineered... d'oh!
  36. G"MAN
    G"MAN GONE LOW BUT GOING LOWER
    82
    would this mod work with the single led bulbs you can get from like maplins or any electronics store.. ??
    G
  37. Scott
    1,306
    126
    I'm sure you could probably to get it to "work" with enough effort but would it look good? no, probably not - you need proper fitment bulbs really which send light in the right directions.
  38. G"MAN
    82
    :unsure:umm ok then i will have a look anyway see what it looks like and will let ya know..
    thanks buddy
    G
  39. Gryphon001
    Gryphon001 Active Member
    303
    44
    From what I understand the holes are already there but plugged. The wireing for the doors however is not, so you would have to run wires to the doors. There is a thread on the Fortitude forum somewhere about putting in some footwell lights but never found anything about pudle lights. All other lighting will work fine and for the interior you don't need resistors. That only applies to the outside lights like the plate light and the side markers.
    Hope that helps...
  40. brissett
    brissett Member
    41
    thanks gryphon that info clears things up a little on the work that would be needed.
