That bigger oil filter...
NineNails Jul 19, 2011
  1. aragorn
    18,542
    865
    maybe i just remembered wrongly!
    Wonder if it would clear the boost pipework on an S4 though?
  2. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,734
    165
    I'd say probably not. My filter is only narrowly off the air con pipes. Unless the air con pipes are routed differently on the S4?
  3. Wizza
    Wizza Member
    750
    15
    Saw this thread the other day but forgot to post.
    Is the bigger oil filter the same case with the 8L A3's? As I nipped into today and asked at Warrington and they mentioned the following part number... 068 115 561F ...and price was £11 - any idea aragon?
  4. mike-a
    mike-a Member
    103
    Isn't the A3 transverse and therefore has a larger sump/oil capacity? I think the main point of the larger filters on the A4 is to increase capacity and avoid cooking the oil with the turbo too much.
  5. Jason.s
    Jason.s Active Member
    2,879
    348
    £11.86 inc vat yeah. But yes the optional filters will fit on transverse 1.8T`s. Looking on ETKA the optional large filters were listed for the likes of AGU and AUM and so on.
  6. Wizza
    Wizza Member
    750
    15
    Aye my engine is AUM. Cheers for info :)
  7. alin81
    alin81 New Member
    Hi ,
    Been watching this and would like to add something for the people who have a 1.8t with transverse engine in case they don t like the way the bigger filter fits...I had the B version on my toledo 1.8t auq and it fits no problem but I had to put some cardboard to protect the lower radiator hose from the oil filter..and I researched the net further to find a oil filter with the same specs as the stadard one(mann w719/30 aka 06A 115 561 B) and I found one.. same thickness but longer...have it on my car and has the same bypass setting ..its a mann w730/1 or the mahle oc221 .
    The only difference is the length...stock one is around 120mm long and w730/1 is 170mm long :) and there is no need for me to put anything to protect the coolant hose .
    As for the bigger thicker one I am also going to try the mann equivalent of mahle oc470/068 115 561 F wich is W 940/66 [​IMG]...and since its used in the latest 1.8t cars like seat exeo I guess it superceeds the w940/25 aka 068 115 561 B .
    P.s Not sure if its just me but I have the feeling that my car has more torque at low revs with the bigger oil filter ?!
    I thought I d share this :)
  8. mojocvh
    mojocvh Member
    167
    Not too sure about some of your Mann references there....
    However, using dimentions from the MANN catalogue the difference in volume from W719/30 to W940/66 calculates out at 54%.
    I am assuming [in this non dissected calculation] that the INTERNAL VOLUMES may very well change in direct proportion from smaller to larger filter, it is obviously of benefit to upsize away from the stupidly small "stock" referenced filter that you may be sourced at motor factors....
    I removed my transporter filter last week as I didn't like the way it was impinging on the power steering hose BTW.
  9. fullpower
    fullpower Member
    159
    Read this whole thread then looked at the date.
  10. mojocvh
    mojocvh Member
    167
    Why??
