Tfsi turbo on a s3/TT ?
Goubo1 Oct 25, 2013
  1. olethalb
    olethalb Active Member
    357
    76
    haha what size DP did you get on there bud? i managed a 3" on hamidis bora 4mo i fitted a tfsi motor to, but is was very tight
  2. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    3" more than enough room around the prop shaft.. Was tight on one of the studs to turbo but easily enough to fit and do up.. I think a 3.5" -3" could be made up if needed...
  3. olethalb
    357
    76
    i think i had 5mm between bulk head / prop donut and subframe
  4. olethalb
    357
    76
    liquids3 and s3dave like this.
  5. superkarl
    superkarl MAN OF STEEL
    9,369
    2,367
    Dave has managed to fit an 86mm Down pipe.
    He must be a wizard
  6. olethalb
    357
    76
    holy hell, i'd like to see pics of that - must have been tight to say the least
    stock engine mounts?
  7. olethalb
    357
    76
    This should have been second pic
  8. Prawn
    11,368
    3,232
    Is hamidis Bora up and running yet Olly? that's not the blue one that was at Rtech is it?
    Any issues with the DP heat and those gear shift cables so far?
  9. olethalb
    357
    76
    yes bud it's up and running - made 361bhp at the hands of Niki but qpengs lpfp 'workaround' is shocking so was limited by that.
    will be sorting a better solution when the weather picks up
    the Dp is wrapped but i'm sure i 'manipulated the tunnel heat sheild to hold them towards the passenger side and no issues so far. :)
    it was the black one btw
  10. beachbuggy
    1,931
    201
    [​IMG][/URL]
    [​IMG][/URL]
    Well here it is..
    Bad idle was totally my fault.. I received the wrong size pipe work for the DV, so I blocked the inlet to the TIP and left the DV venting to air! ...mmmmm that was the problem... So it idles perfectly now..
    Dp still knocks.. So larger dent needs to be purchased ;-) or subframe needs grinding back.. I think it'll be easier on a ramp..
    [​IMG][/URL]
    Gops, dusty, AJC and 4 others like this.
  11. beachbuggy
    1,931
    201
    I've got a DIY large inlet to go on once it's been run in and some data has been been gotten on the stock manifold.
    and all the nuts from the strut brace are safely stored somewhere.. And will remain there , where ever that is!
    Broken Byzan likes this.
  12. Munch
    Munch Member
    256
    23
    Much like most people......I am very looking forward to seeing this develop.
    Will have a freshly built Agu next year awaiting a bbt TFSI setup :)
  13. Ivo
    Ivo Member
    55
    Any news on the TT build?
  14. dusty
    dusty Active Member Team Nogaro Blue Audi S3
    267
    46
    I'm very interested in this also I would like to go with this turbo after my engine rebuild
  15. Gops
    3,192
    655
    What oil/ water lines did you use? B6 1.8t or stick with the tfsi ones?
  16. Pedrosousa
    Pedrosousa Member
    174
    I think I've read the stock from the 1.8t the only change was in the oil drain. Am I wrong???
  17. Gops
    3,192
    655
    The oil drain is custom... But I read on prWns thread it's b6 a4 1.8t lines or tfsi.. But just checking innit :)
  18. Prawn
    11,368
    3,232
    None of the lines are from a stock 1.8T transverse car.
    my oil drain is made from 2 ko3 oil drains cut and welded. The rest Dan supplied I'm afraid so I'm not sure!
  19. future
    future Scuderia Vittoria Edition 001
    371
    33
    sorry to be an eager beaver but do we have any more info on this? itching to give dan my card details you see...
  20. Prawn
    11,368
    3,232
    I believe the car is up and running and driving now, awaiting some running and dyno time to follow last I heard :)
    I'll give Dan a nudge, see if he can give more details
    Rainbird likes this.
  21. beachbuggy
    1,931
    201
    Car is running and driving..
    Major knocking from exhaust is gone, but its rattling on the underside still so need to address that.
    I also need to remake the turbo charge pipe as its rubbing on the prop shaft when it goes over a bump..
    Only running it on actuator at the moment but does feel good, and spools nicely.. Once I've changed the oil tomorrow and sorted the charge pipe I'll give it stick and see what it's really upto..
    I know you can't compare like for like but the same turbo on the 2ltTFSI engine made 403bhp so it's more than capable, just need to see if the engine is upto it..
    Rainbird, Pedrosousa and Gops like this.
  22. daz-20vt
    daz-20vt Well-Known Member
    2,827
    580
    So are you going to be selling as a whole kit. If so whats going to be included. And will you be selling parts seperatly. Just out of interest. Daz
  23. Gops
    3,192
    655
    Judging by what prawns did, it spool slightly later but held as the 2.0 did.. You think this would do the same? Also I was looking at the Loba unit, they seem to cut off the intake pipe on the Turbo, would that benefit anything or is just that them butchering the turbo as they do?
  24. Pedrosousa
    Pedrosousa Member
    174
    Gops, that Loba it's a different turbo, look again, the Loxx it's the TTRS turbo in the k04-064 exhaust side.
    Water and oil line are easy to do Check the Trip Team facebook photos.
    I think that the intake curve it's a limitation of the k04-064, is good idea to port it??
    What's the site of the compressor Wheel used on the hybrid??
    s3dave likes this.
  25. future
    371
    33
    awsome! thank you for the update, will keep my eyes on this closely now. Good luck with the testing dan and look forward to your results! :thumbsup:
  26. Gops
    3,192
    655
    The 4xx doesn't have that intake curve whereAs the ttrs turbo does! I'm wondering if it's better to cut it off and stick a badger5 80mm billet adaptor on for a true 80mm tip.
  27. badger5
    9,366
    1,911
    imho, hotside limited
  28. Gops
    3,192
    655
    How did the porting go bill? What car was that off?
  29. Pedrosousa
    Pedrosousa Member
    174
    Bill, what about the cold side??
    What do you think about that curve TIP?
