Tfsi h&r springs on a tdi
Henry1302 May 28, 2013
  1. Henry1302
    Henry1302 Member
    31
    Quick question, might be a daft one.
    A mate has some h&r springs off his s line tfsi will they fit my s line tdi or are they different due to the heavier Diesel engine?
  2. Ads
    Ads License to drive
    8,230
    613
    Check H&R's website for the part number of the springs for both models, and if they are different then I wouldn't do it.
  3. TDI140
    TDI140 Well-Known Member
    1,632
    175
    Both had 55mm struts if they at both 2.0tdi and 2.0tfsi but check website as ADS has said
  4. Henry1302
    Henry1302 Member
    31
    Cheers chaps I've had a look at a few H&R suppliers websites and they seem to just offer one package for the whole 8p range so i'm assuming they will fit based on that?
  5. Rhyso
    Rhyso Well-Known Member
    1,547
    323
    Springs should be model specific. The TDI engine is a fair bit heavier than the TFSI!! You may find that the TFSI springs are too bouncy
    physically they will fit
    i stand to be corrected but on my last car I had to make sure the springs were for the TDI model
  6. Ads
    8,230
    613
    That's not correct as H&R must offer different springs as the weights involved are different... i.e. Quattro, FWD, engine sizes.
    Don't take what the suppliers say as gospel, visit H&R's website for the proper info.
  7. Henry1302
    Henry1302 Member
    31
  8. Henry1302
    Henry1302 Member
    31
    I've just had a look on the parkers website for facts and figures and it reckons the tfsi and the tdi 140 are the same weight as on supplier sold 2 different spring sets for the a3 2wd 8p one was for below 1020kg and the other was for above.
  9. Ads
    8,230
    613
    FWD and Quattro use different springs though. If you've got the same drivetrain as your mate then it's all good, if not then his springs will be no good for you.
  10. Henry1302
    Henry1302 Member
    31
    Cheers for your help, were both 2wd so all is good. Thanks again.
