TFSI Conversion anyone?
turnstyle Oct 17, 2012
  1. turnstyle
    turnstyle Member
    91
  2. <tuffty/>
    21,951
    4,228
    Nice.... wonder if that would work on a 2.5ltr TTRS engine swap too :eyebrows:
  3. Sam_
    Sam_ Down under
    3,038
    480
    It'd be cool to run DSG I think too (commence abuse).
  4. turnstyle
    turnstyle Member
    91
    Oh man - 5 pot burble!! nothing beats it
    ...... well..... the fuel consumption does i guess haha! :D
  5. <tuffty/>
    21,951
    4,228
    Would be past worrying about that as it would have a GT35 attached to it lol...
    turnstyle likes this.
  6. Sevv
    Sevv Pushing the limits..
    1,324
    120
    now that would be a nice little moster car...
  7. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    This guy has a build thread on ukmkivs,think he spend about 5+ grand getting the conversion done!
  8. turnstyle
    turnstyle Member
    91
    Im sure it could be done cheaper.
    Once you've completed the swap you could sell off ypur old engine to recover some of the cost.
    Im sure someone with an A3 etc would want it to have more power
  9. Paradox1
    1,833
    88
    I think this was done a while ago when the 2.0 turbo engines came out so they were pretty new at the time
  10. Gops
    3,198
    666
    This is interesting, I've been reading about this alot recently as an alternative to a BT build. Obviously you'll get more power from a BT build but probably day to day that conversion would do sweet! Mmmm ;)
  11. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Isn't Arron still doing this on here??
  12. turnstyle
    turnstyle Member
    91
    Cant these handle a fair amount of power?
    Its not something ill be doing - ive only just got the car haha.
    Its just something i came across while looking into swapping to a bigger engine(dont ask why... i dont know), and figured it may help anyone who is going to do the swap.
  13. Gops
    3,198
    666
    They can handle a far few horses, but being Safe I'd pop some rods in and go hybrid! This is a good conversion!
  14. Prawn
    11,708
    3,712
    I looked into this a while back, it appears you can use as much or as little of the TFSI stuff as you chose.
    Apparently the 20vt head bolts right onto the tfsi block too.
    I looked into the possibility of using a tfsi block to go 2ltr with all 20vt parts bolted to it, but I think the truth is, they're only being claimed as 'safe' to higher power levels because they're so much newer.
    people are bending rods in these, just as happened with the 1.8t 6-7 years ago as they started to get older.
    I think in 5 years time it'll be accepted that tfsi's need rods to make big power too, and there won't be a HUGE gain to be had from it.
  15. lloydie1
    lloydie1 Member
    68
    DSG has been done on a 1.8T already !
  16. Gops
    3,198
    666
    Totally right! If your gonna do the conversion it's probably my safe to uprate rods anyhow. The ko3 tfsi engines are weaker than the BHZ and CDL engines aswel! Couple of mkv guys converting to a ko4 have had rods bent! I think the 8p came with reinforced rods, crank, pistons and pins.
  17. Yohan87
    Yohan87 Guest
    The TFSI heads are 16v aren't they?
    How do the port sizes compare to large port 1.8T?
  18. slydog18
    slydog18 N88GGY S3
    139
    Aaron is now going big turbo on a 1.8.
