tfsi a bit jerky when cold
sliced Aug 20, 2013
  1. Sevv
    Sevv Pushing the limits..
    1,324
    120
    do a carbon clean of your inlet mani and the head on the inlet side.. im quite hopeful the juddering will go away and clean them injectors too just give it ago Sliced :) .. and you can also delete the flaps on the mani while your at it if you decide to take it off
    sliced likes this.
  2. TDI140
    TDI140 Well-Known Member
    1,626
    174
    I have this problem on my 2.0tdi if its in a low gear its fine when cold but if i put it in say 4th at 30mph it does it like jerks as if its about to stall but give it some more revs and its fine again, ive had i jectors replaced by audi it seemed to have sorted it though since i added an oil catch can and cleaned all boost hoses so there tight and secure, so i think you should all check boost hoses to see if there loose or have oil in them, my problem is back now again as my jntercooler still has oil build up due to turbo blowing up earlier this year
  3. TDI140
    1,626
    174
    So check the boost hoses and clean them out and report back if it fixes the problem
  4. sliced
    sliced Drive safe, stay alive.
    1,559
    334
    All hoses checked today, all fine, however checked all the cars hoses and found this in my sisters car!!! ImageUploadedByTapatalk1380472239.752281.jpg
    God knows how she didn't notice driving with a split breather hose
  5. sliced
    1,559
    334
    Cheers will attempt this next weekend! Fingers crossed :happy:
  6. Sevv
    1,324
    120
    i hope it will cure it .. i know mine juddered cold or hot and it was due to the inlet and injectors carbon build up so i hope my fix will work for you! btw even 'if' it doesn't fix it ... its preventative maintenance your motor will love you for it :)
    as for your sister HOLLY S*it thats shocking...women are clueless generally hehe
    sliced likes this.
  7. sliced
    1,559
    334
    Update:- scanned with vagcom threw code for P0301-000 misfire detected cylinder 1 - intermittent
    Going to get a new coilpack and get that fitted sometime this week. PS does anyone know which one is cylinder 1?
  8. Marshy
    Marshy Settled in Audi RS3
    1,352
    468
    Cylinder 1 is timing belt side so drivers side of the car.
    sliced likes this.
  9. sliced
    1,559
    334
    so the one ive circled in green is cylinder 1?
  10. Marshy
    1,352
    468
    Yeah that's it.
  11. Scoobaru
    Scoobaru New Member
    12
    I have this 'jerky when cold' symptom as well. It appeared after getting a Shark remap, very noticable on light throttle when cold in 2nd and 3rd between 2500-3000rpm. Changed the plugs and it improved things but it still happens. I've never had any engine lights on the dash, how about you ? Not had VCDS on it yet.
  12. sliced
    1,559
    334
    oops forgot to reply, changed the coilpacks and now the problems gone
    CHEZ likes this.
  13. stony2002
    stony2002 Member
    how much did the coil pack cost you/normally cost for a full replacement
  14. sliced
    1,559
    334
    Think it's about £30 a pop
