Texture paint... ROCKS!
Geeman Apr 1, 2010
  1. Geeman
    Geeman Low Life
    1,318
    Found some texture paint on eBay. It's not cheap, but the results are REALLY good.
    I bought this to use on parts for my Mk2 Jetta, and I've been playing with it over the weekend - **** pictures I know, but if you can imagine somewhere in between the two (flash and no-flash)... it looks like a proper factory finish! You prep your item with etch primer, then matt black it, then lightly spray this stuff on it. You only need a very light covering to get the right effect. Too much and it dries smooth. Touch dry in about 20 seconds... Awesome!
    I think I'm going to do something custom with the Jetta grille this time. Going to try and not over do it with this stuff, but I can see myself getting a bit carried away with it!
    Find it here:
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220564172782&ssPageName=STRK:MEWAX:IT
  2. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,767
    31
  3. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    yuk .... how does he wash that car?
  4. aragorn
    17,889
    689
    Same way you do...
    Its not an S4, its a fwd a4. Hes since changed the wheels and painted the bedliner in audi silver.
    TBH it would look far better in black, its not so much bad as different.
  5. voteforpedro
    voteforpedro Member
    632
  6. nwmlarge
    nwmlarge flat out
    219
    not what you'd call cheap that plasti-dip!
    did you use primer etc ?
  7. voteforpedro
    voteforpedro Member
    632
    Nope, just scuffed up the chrome paint a little and sprayed away. Been on for a year now and probably been hit by a million stone chips and it's still solid, no flaking at all.
  8. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Could post up some pic's of the item's you used the plastic dip on. ta.
  9. voteforpedro
    voteforpedro Member
    632
    Not great photos sorry:
    But you can see how nicely it matches the rest of the grill.
  10. CMD
    3,015
    17
    Thank's
  11. theviking
    theviking Member
    149
    washed it with sandpaper
  12. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Geeman. I like that look a lot. A lot of OE engine covers are painted like that. I am probably going to do my Audi grill rings in that now! nice one!
  13. aragorn
    17,889
    689
    I've got a can of Black VHT Wrinkle, but i cant decide if i should do the valve cover or not :/
  14. Foxmeister
    Foxmeister Fired Up!
    1,785
    Seen a lot of RS owners(Ford) getting into this the last couple of years, referred to as "Crackle black" finish, think powder coaters do it, looks excellent!
  15. phoenixv6quattro
    1,396
    Yeah it does look excellent. A nicely sprayed up rocker transforms the whole look of the engine bay.
  16. Geeman
    Geeman Low Life
    1,318
    I think rocker cover and inlet manifold would look good in this stuff...
  17. Foxmeister
    1,785
    Yep, mostly rocker covers, header tanks, swirl pots etc ive seen, and looks great when it all ties together in the bay, understated but lovely!
    I vote you do the rocker Aragorn, will look cool!!! I'll try dig up some pics for you's!
  18. phoenixv6quattro
    1,396
    You got my vote too! Fair play if you do it and good luck!
  19. Foxmeister
    1,785
  20. phoenixv6quattro
    1,396
    That YB (sharkey) looks lovely....
