Testing my ultrasonic cleaner :) HELP
camscockle20vT Dec 25, 2011
  1. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    77
    Hi all merry christmas and all that. So im sad enough to still be lurking asn and i though hi ho ill give my new ultrasonic cleaner a blast, so im using water and a drop of fairly liquid but the theing is buzzing like mad lol is that normal? And when i do my injectors should i just use water? Thanks for helping a slightly merry child with a new toy :)
  2. Prawn
    11,355
    3,197
    Buzzing is normal, don't worry. I got my dad one for Xmas, and I'm already sick of the noise!
    I used the proper 'James: sea clean' solution when I did my injectors. Not sure I'd want fairy inside them, so perhaps just warm water.
    I'd give them at least 3 cycles of 5 minutes, with clean water each time
  3. Prawn
    11,355
    3,197
  4. camscockle20vT
    1,740
    77
    Thanks for that dude, its a really handy bit of kit tbf, not sure about the 1000 uses but iv already cleaned jewllery and cds :) what other components of the 1.8t can benifit from a blast?
  5. Prawn
    11,355
    3,197
    Worth bashing your FPR in there whilst you've got it all apart I reckon
  6. camscockle20vT
    1,740
    77
    Old topic but i was wondering how to pull my injectors out? Take it that un plugging the battery and take the petrol feed pipe off is the basics but do the injectors just pull out? Or is there clips to be pressed in then pull? A linkey would be nice please :) as my laptop is out of reach and search is poo on tapa talk, thanks for any help.
  7. Prawn
    11,355
    3,197
    run the engine and pull the fuel pump fuse, think it's no27. that'll de-pressurise the system.
    Then just undo the 5mm allen bolts that hold the fuel rail down, remove the wiring loom, and pull it off!
    the injectors will come out in the rail, then there's 4 little clips to pull the injectors out of the rail :)
  8. Westy
    Westy Well-Known Member
    17,440
    1,097
    By the way. I used washing up liquid on injectors when I leant someone the proper solution. They were fine.
  9. camscockle20vT
    1,740
    77
    Wiked, shall do this the weekend :)
  10. camscockle20vT
    1,740
    77
    Ahh good to know, the instruction manual says to use 3 quaters water and 1 1/4 washing up liquid.
