Testing Dumpvalves
tonybolony Aug 31, 2013
  1. tonybolony
    tonybolony Member
    138
    Is there way to test if DV are failing?
    I have fitted a Boost Gauge as i was sure my car wasn't boosting fully, and i can now see that its getting to about 0.5 Bar or under and cant hold it, i have checked and listened for leaks, i also disconnected the MAF in case that was been a divvy, so i am now thinking DV's ? they are the originals and have covered 164,000 and are 15 years old.
  2. Bradderz_1988
    3,958
    238
    Pull them off and blow through the side port if you go red there fine if you can blow through it replace them !!
  3. S4 Muzza
    S4 Muzza oww! my giant blue head!
    350
    29
    Use a pen or something to push the piston up from the bottom and cover the top hole with a finger. If the piston stays where it is all is good, if it slides down its not holding pressure.
    bulletproof methodology.....
  4. tonybolony
    tonybolony Member
    138
    so i tested my DV's and i push them to the top cover the hole and they drop about half way back down, then i let my finger off and they plop totally back down, so i am guessing they work, or should they stay right at top and not come down at all?
    My Boost gauge shows vacum 0f about -7 -8 on idle.
    i cant hear any leaks so i am totally stumped :-(
  5. Broken Byzan
    13,237
    465
    Have you scanned the car for faults? It sounds like limp mode. I assume you have a 2.7?
  6. tonybolony
    tonybolony Member
    138
    no just downloaded the VCDS Lite so i will try a scan later
    yes it is a 2.7 Bi Turbo
  7. hades-
    9,481
    646
    smoke test
  8. tonybolony
    tonybolony Member
    138
    not sure what you mean by smoke test, if your refering to if my turbos smoke at all they dont, i get nothing out the back of the car other than the usual :)
  9. S4 Muzza
    350
    29
  10. tonybolony
    tonybolony Member
    138
    well as i put on a new thread these are the faults i got
    As discussing an earlier thread these are the log readout for my car.
    The engine has been out, due to blown turbos which i replaced
    as i said the units are firing up but not past 0.5 bar and the boost doesnt always hold, naturally the faults standing out are the boost pressure control valve and the purge valve, have i done something wrong :-(
    11 Faults Found:
    17833 - EVAP Purge Valve (N80): Short to Ground
    P1425 - 35-00 - -
    17938 - Cant Find
    P1530 - 35-00 - Please Register/Activate
    17955 - 17955/P1547/005447 - Boost Pressure Controle Valve (N75): Short to Ground
    17697 - Boost Pressure Control Valve (N249): Short to Ground
    P1289 - 35-00 - -
    16486 - 16486/P0102/000258 - Mass Air Flow Sensor (MAF/G70): Signal too Low
    17861 - Cant Find This
    17865 - Exhaust Gas Temp Sensor 2 (G236): Open or Short to Plus
    P1457 - 35-00 - -
    17523 - Cant Find This
    P1115 - 35-00 - Please Register/Activate
    17527 Cant find this
    P1119 - 35-00 - Please Register/Activate
    16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
    P0134 - 35-00 - -
    16538 - 16538/P0154/000340 - Oxygen (Lambda) Sensor B2 S1: No Activity
  11. Broken Byzan
    13,237
    465
    At least 3of them would cause limp mode. Especially 02 sender egt and maf. I'd check fuses because an awful lot of fault s there that bi believe share a fuse.
  12. tonybolony
    tonybolony Member
    138
    what if i have got the earths wrong, as in ones on engine should be on chassi and vice versa, or would that not matter?
  13. Broken Byzan
    13,237
    465
    shouldnt do no, as long as the body is connected to the engine it should be ok. I assume you havn't perhaps trapped a wire in between anything when you had engine out?
  14. tonybolony
    tonybolony Member
    138
    well i dont think so i will have to have a good check over
