Test for boost leaks
1animal1 Aug 14, 2008
  1. 1animal1
    9,978
    Does anyone know of a simple test for boost leaks....i have checked where possible for split pipes but would like to make certain that no other leaks exist.
    I have read about certain smoke tests and pressure tests but haven't checked on what is associated and costs etc...anyones any ideas of these or similar tests
  2. abdus
    abdus Top Gear VCDS Map User
    1,827
  3. 1animal1
    9,978
    cheers abdus, im gonna have to try and source a compressor and valve... definately a really good guide
    if any easier suggestions come up ill be interested
  4. 1animal1
    9,978
    just thinking out loud, im gonna try and source a 'bike' air valve tonight(threaded if pos might be a long shot)so that i can attach the car tyre compressor to the can...... needing a non return valve to rid the threat of back pressure once the system is charged upto 15psi
  5. Jimmeh
    Jimmeh Active Member
    1,438
    Tim, if you have any joy with this, do let me know. I'm yet to check the obvious areas (TIP?) but am sure I am loosing some boost somewhere due to the max reading from a VAGCOM run being a bit off 'default'.
  6. dansansome
    dansansome Member VCDS Map User
    165
    how about buying a bicycle inner tube and bonding the valve of that to the can (from the inside, so that when the system is pressurised, it aids the seal).
    you might be able to get your entire shopping list from halfords :)
    might try this myself....
  7. 1animal1
    9,978
    was thinking along the lines of a 'racer' tyre valve as they were always threaded all the way through and wacking two rubber seals together
  8. mac1403
    mac1403 Member
    972
    I knocked this up for my A4. Maybe you could do something similar. Measure dia of the pipe off the airbox. Go to B&Q an get some plastic pipe the same dia and blank end plus some strong adhesive and if you can an American airline fitting (fits perfect onto a portable tyre inflator) I know its a bit Blue Peter ish, but it worked a treat on the A4
  9. 1animal1
    9,978
    cheers Mac..... where did you get the american air line from? i think the can will be the easiest to use as i wouldnt have to seal the end cap etc, but the valve is the bit with the question mark at the minute....never made it to bike shop last night, hopefully get to a halfrauds today
  10. mac1403
    mac1403 Member
    972
    i might have one lying around if you send your address i will post it
  11. 1animal1
    9,978
    Cheers Mac, i'll give Halfrauds a go tonight, if i cant get ahold of anything ill pm you my address - really appreciate that mate
  12. 1animal1
    9,978
    okies an update...... i have made a unit using a can and a fully threaded valve from a push bike...... hooked it upto the TIP which is 80mm in diameter...the can is only 75mm (could be slight pressure loss here)
    ive used a normal compressor to push air in, noisey damn thing too!!! the pressure wasnt getting ver 2-3bar so think i either have aserious leak which isnt showing on VAGcom or i need something that will fit the TIP better.... once i removed the airline.... there is pressure holding as 1 minute later i released the oil cap which was under slight pressure..... just need to make sure the entrance unit is air tight, next step may be to replace the oil filler cap/neck.
    Mac.....what was the diameter of the pipe you used as i cant find anything except guttering that is 80mm, which you just so happens cannot buy a stopper cap for
  13. 1animal1
    9,978
    anyone got any suggestions on a can type cylindrical unit to fit onto the TIP....needs to be 800mm diameter...been to few DIY shops and cant find anything immediately obvious
  14. Morgan-VAGCHECK
    Morgan-VAGCHECK Foot to the floor
    103
    Just one thing..
    You really do not want to be applying 2-3 bar pressure with this method !
    You could end up a very unhappy chap !
  15. 1animal1
    9,978
    Morgan, ive only tried this twice after MAF..... and both times noticed blue smoke for 1 minute on idle afterwards......
    Whats your thoughts on this....i have followed the instruction of the golf/A4 guys who have posted
  16. 1animal1
    9,978
    obviously the blue smoke prompted a slight leak of runny poo to dribble uncontrollably down my left leg only to enter the top of my sock and stop short of the heel....thank god for that!!!
  17. HTC
    HTC Active Member
    3,428
    9
    You are probably forcing pressure into the crankcase via the pvc system. I'd remove the PVC valve from the TIP and plug the hole before trying again.
    I wouldn't go above 30psi or 2 bar personally.
  18. 1animal1
    9,978
    HTC, what would the PVC system look like? may also be an option to pump air in here and block the air box off.......
    firstly what are the dangers of going over 2 bar, secondly will plugging the PVC system stop pressure building below the oil cap?
    apologies, im not the most experianced DIY mechanic:thumbsup:
  19. HTC
    HTC Active Member
    3,428
    9
    It's the pipework that allows the pressure and fumes from the crankcase during running to be sent into the inlet manifold and TIP depending on whether you are on or off boost.
    The pipe I'm talking about is the one that runs from the top of the cam cover on the passenger side to the plastic disc valve at the TIP. I'm not sure how how much pressure (if any) it can take in the wrong direction. You don't have to worry about the N75. When it's de-energised it connects the turbo outlet to the actuator which you'd want to test anyway.
    The one way valve at the front of the block under the inlet manifold stops pressure going into the crankcase so you shouldn't need to worry about that either.
    If you pump up the carnkcase too much then you'll be forcing oil up into places it wouldn't normally go. Past gaskets and past valve stem seals etc.
    You only need to test up to what you expect your maximum boost to be. I'm pretty sure testing as you have been with the PCV removed from the TIP and the hole blocked is the correct way. You won't get pressure under the oil filler then.
    Hope that makes sense.
  20. 1animal1
    9,978
    thanks HTC
    in summary i need to block the pipe from the TIP to the plastic disc valvey thingy, i gather i wont need to block the disc outlet as this is part of the vacuum system rather than the boost? having already put pressure through and having no running issues other than the previous problem (no VAG faults either), can i assume the valve is still intact
    one other thing ive noticed (not sure if this is part of the problem)is that when i secure the front boost pipe to the solid pipe that sits on top and to the left of the upper engine.... the pipe always seems to have slipped 2-3 mm, gonna replace the clip this weekend as its a bugger to tighten.
  21. 1animal1
    9,978
    buggar...... understand what your saying now HTC.... thanks again:laugh::thumbsup:
  22. themanthatcan
    themanthatcan Member VCDS Map User
    661
    I think that's pretty normal Tim. Mine does it and most the engine-bay pics I've seen of the 1.8T have bee the same.
  23. 1animal1
    9,978
    think im gonna replace it anyway and whip the bumper off the next chance i get to tighten and secure everything....belt and braces
  24. 1animal1
    9,978
    Jay, thanks for the tip mate, bought couple rolls of PTF tape to build the can seal up:salute:
  25. abdus
    1,827
  26. Broken Byzan
    13,237
    465
    ^^ Thats what i have, he made a slightly smaller one to fit the A4 1.8t, Works a treat at only a few Lb. If you have a leak usualy its evident when you presurise. If its not hissing at 2 or 3 bar, it probably isnt leaking IMHO
  27. 1animal1
    9,978
    thanks Abdus, i cant view it as cant get ebay at work.....still havent got around to checking mine yet although i agree with Byzan, 2-3bar should do it.
    After driving and monitoring the situation i think it only happens on max boost in 3rd gear mostly, this to me should hopefully indicate a boost leak but most liklely a pipe that needs tightening as opposed to split pipes...otherwise it would kick in all the time in theory of course
