Temperature Gauge
Pubemammal Oct 2, 2013
  1. Pubemammal
    Pubemammal Active Member
    530
    117
    43
    Since I got my car the temperature gauge has been rather odd. It will take a long time to heat up but when it does it sits on about 60... unless in traffic it sits on 90. If going around 70-80 mph on the motorway it drops right down to almost zero.
    Ive got no problems with getting hot and cold air out the blowers even when temp is showing zero. Could this be the thermostat or more likely temp sensor?
    Lately the idle has started hunting up and down for a few seconds then eventually settles down... unless the air con is on then its fine!? Related? Or more likely MAF issue? I will unplug it to see if its the MAF later on.
  2. aragorn
    18,612
    872
    Its the thermostat.
    Your wobbly idle could be a split breather hose or similar.
  3. Pubemammal
    530
    117
    43
    Thanks for replying. I will order a thermostat. Could a split vacuum hose cause the idling issue?
  4. aragorn
    18,612
    872
    yeh thats what i meant by breather hose or similar :icon_thumright:
  5. Pubemammal
    530
    117
    43
  6. JudderMan
    JudderMan Well-Known Member
    1,026
    172
    I swapped my thermostat and a wobbly idle disappeared too. A garage wrongly thought the idle wobble was the HG :think: Make sure you 'burp' the system after putting the new stat in (run it with the coolant header cap off, put it back on, go for a drive, top up coolant as necessary).
    btw, if you have very small hands fitting the stat will be a doddle...if not...it's a PITA. Use an allen key on the top of the left bolt, that's the only way I could do it. Such a fiddly job for what is just a two bolt job.
  7. Pubemammal
    530
    117
    43
    That's promising. .. hopefully kill two birds with one stone. Thanks for the advice I'll fit the new stat at the weekend :) although... my hands aren't small :'( lol.
  8. JudderMan
    1,026
    172
    LOL, OK dude, if you've got big hands you'll have the same trouble I had. Even drafted in my dwarf mate (not really a dwarf but he's small) and he struggled. If I had to do it again, I'd take the whole front end off first :)
    Oh and you might as well do the N249 bypass while you're kicking around that area.
    Good luck!
    Pubemammal likes this.
