Temperature display
denzelburner Nov 14, 2008
  1. denzelburner
    denzelburner Member
    166
    Last night, the display for my clock and thermometer just turned red, as in backlight, but no info. I was wondering if anyone else has had this, and how to rectify this. It's the display inbetween the speedo and the rev. counter. Got a mind blank at the moment, and can't for the life of me remember the things name :banghead:. I might need to get a new one anyway, as it's doing the typical fade out as it gets warmer, but I'd rather not at the moment.
    Thanks in advance
  2. audinary
    audinary Complete And Utter Member
    676
    That'll be the DIS display. Driver Information System. And they all seem to do that..... Mines fine except the top left corner of the topmost part of the display.
    Mind you, one day it couldn't be bothered at all, but came back the next. It may be haunted.
  3. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Just turn it off for a few days and it'll be fine. Replacement isn't cheap or simple.
  4. denzelburner
    denzelburner Member
    166
    Thanks everyone :happy:
    Does turn it off mean keep the car off, or just the DIS?
  5. Siena
    Siena Active Member
    2,626
    Just the DIS.
    So far, mine in my 12-year-old car hasn't missed a beat.
    When it does, I'll just install my STACK dash, as far as I'm concerned, the info on the DIS is useless, I'd prefer oil pressure, fuel pressure, and on a 1,8T, boost pressure.
    Might as well rename the damn thing "DUI" - Driver's Useless Information.
  6. denzelburner
    denzelburner Member
    166
    Lol, how do I turn it off? is it just a case of removing the wires from the back? Are there any replacements for the DUI?
    Mind you, it does give me advance warning as to wether i need to put my hat on or not before I exit the vehicle. A very important thing in my eyes, lol.
  7. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    dont you just use the DIS controls (up or down) on the wiper stalk until it goes off? or the reset button underneath?
  8. aragorn
    18,608
    871
    i think the reset button underneath turns it off if you just press it once rather than holding it down.
  9. denzelburner
    denzelburner Member
    166
    I don't have any buttons on my stalks, it really is a DUI. It doesn't have a trip computer or anything like that, it just tells, or told me the temperature and something else, but can't remember now. It really is that usefull. I just want to sort it out as it's bugging the hell out of me :banghead:
  10. aragorn
    18,608
    871
    yours must be an SE then? Just has 4 large indicator lamps in the middle of the dash with two smaller lines under it?
  11. Siena
    Siena Active Member
    2,626
    Oh, I see.
    Just an ambient temperature display then.
  12. denzelburner
    denzelburner Member
    166
    Yes, to both. Is there any replacement?
  13. aragorn
    18,608
    871
    i'd get vagcom on the instrument cluster to see if the sensor has failed or not.
  14. Siena
    Siena Active Member
    2,626
    Unlikely to be the sensor.
    If the sensor's even unplugged at the front, it just shows a max value on the display, rather than nothing.
  15. Siena
    Siena Active Member
    2,626
    Cost is about £110 from memory.
  16. denzelburner
    denzelburner Member
    166
    Blimey, just for an external temperature display!
  17. Siena
    Siena Active Member
    2,626
    I'm afraid so, Denzel.
  18. denzelburner
    denzelburner Member
    166
    Again, is there anything else i can upgrade to?
  19. Siena
    Siena Active Member
    2,626
    There are very little options out there.
    The only other option is to retro-fit a cluster with the full DIS system.
    A costly undertaking, as it involves a lot of wiring.
    It also comes with its own set of gremlins, as the DIS display is notorious for premature failure.
    Only option really, is to replace the ambient temperature display, or just get used to seeing it in "black hole" mode.
  20. rasA4
    3,287
    119
    does it or did look like this?
    seems to be different to my petrol engine DIS as mine is a one whole unit like this
  21. denzelburner
    denzelburner Member
    166
    yes, apart from mine doesn't seem to have the bit splitting the temperature reading from the screen showing door open/ low fuel tec, and also less the auto box numbers.
  22. rasA4
    3,287
    119
    take a pic and post it up
  23. denzelburner
    denzelburner Member
    166
    How do I get the phot's on here? I've got them in my desktop at the moment.
  24. aragorn
    18,608
    871
    you need to upload them to photobucket or imageshack, then paste the URL in here!
  25. rasA4
    3,287
    119
    what he said^^^^ dont forget to use there are 3 options under the pic once you have loaded it on photobucket
    e.g. [IMG]www.photbucket.com/etcetctetc
  26. denzelburner
    denzelburner Member
    166
    Here we go, I think:
    and:
    My mistake, it has got the little split thing, just never noticed it before, oops :redface:
  27. rasA4
    3,287
    119
    great you got there in the end, what shows up in the top screen? looks like you dis in only featured on diesels my pic was from a facelift 2.5 tdi.
  28. denzelburner
    denzelburner Member
    166
    the box above the red one shows the low fuel/ low oil/ doors open etc. It's the red box that seems to have given up the ghost. Mine is a facelift 2.5tdi one too, and pretty much the same, bar the auto display. All i can remember is the Temperature is shown, now can't remember what else there was, which is so frustrating :banghead:
