Temp still not right!
pembo1976 Oct 14, 2007
  1. pembo1976
    pembo1976 New Member
    25
    Having the old problem of temp gauge not working on my 2002 1.8t quattro A4 I replaced the temp sensor located at the back of the engine bay. Its now reading a temp wandering around the 60 degree mark when I'm on the move and only sits at 90 (which I think its supposed to be constantly at once up to temp??) when I'm stationary or in slow moving traffic. Is there another temp feed to the gauge? maybe at the radiator thus explaining the temp fluctuation. I was under the impression that the temp gauge had only 1 input.
    Cheers.
  2. golf
    golf ***** rent boy VCDS Map User
    1,556
    There are two CTS's on the 1.8T, the one you've replaced already and there is one at the bottom of the lower radiator hose. It's connected using a plastic retaining clip. It's fairly easy to spot, be warned though if you take off the clip all the coolant will come out in quite some force.
  3. AndyMac
    9,832
    45
    Sounds more like thermostat stuck open rather than temp sender, but I guess it could be either
  4. enda1
    enda1 Member
    436
    Yeah sounds like thermostat to me as well
  5. pembo1976
    25
    Thanks for the replys, has anyone got a part number for a thermostat and how to change?
  6. golf
    1,556
    A bit of bad news for you is that the 1.8T has an electronic thermostat, these are pricey and are a bitch to fit.
  7. AndyMac
    9,832
    45
    If it's electronic does that mean it'll log a fault on VAGCOM?
  8. golf
    1,556
    Yes, it should do. The thermostat's rarely go bad though.
  9. enda1
    enda1 Member
    436
    Golfs right on this. If you can get it out there is a test procedure for this electronic thermostat. I can send it to you if you PM me with an email address
