Temp reading
1animal1 Jan 26, 2009
  1. 1animal1
    9,978
    Hola!! just playing around on the way to work this morning and decided to check the inlet temps.... i think this is option 49 on the aircon unit....
    anyway, sat mostly at 78 C but went down to 69 C whilst coasting down a long hill, is this normal? my temp gauge also went to about 80 C whilst this was happening...whats the diagnosis chaps?:racer::sadlike:
  2. Imteyaz
    Imteyaz 6th Gear
    535
    I could be wrong here (somebody please correct me if I am) but using '49' function on the aircon screen tells you the temperature of the coolant that the ECU will see, not inlet temperature.
    I had the same issue, temp would drop on long journey but steadily rise when stuck in traffic. I changed the thermostat (and dipstick tube as it shattered whilst trying to access the thermostat) and checked again to see that the temp stayed at 90degC once warm.
    Thermostat from a stealer is about £12, dipstick tube about £3 and the grazed knuckles you get from doing the job are free!
  3. Westy
    Westy Well-Known Member
    17,443
    1,105
    yeah if your temp guage on the dash is showing the same as your aircon reading then you'll need a new thermostat.
  4. FazS3
    FazS3 Member
    867
    Thermostat fella
  5. Prawn
    11,715
    3,727
    it's a very typical VAG problem, that the thermostat starts to stick open. it's not doing any massive harm, although it'll take longer to warm up, and won't usually reach 90 on a run. it'll also probably get progressively worse.
    My car runs fine at 90 in summer, but in the cooler winter months, it rarely gets above 70 degrees, which is bloody annoying!
    New stat will cure it
  6. HTC
    HTC Active Member
    3,428
    9
    Theory-o-etic-cally-ish (spelling :)) an engine not running at it's designed temperature might cause raised engine wear.
    I concur, it's a thermostati-cally-isk problem.
  7. 1animal1
    9,978
    cheers guys, i thought as much but wanted clarification..... the temp display isnt showing the same as the aircon yet but assume its best to change
    will do a search for the guides to replace......
  8. V.I.P_UAE
    V.I.P_UAE Member
    117
    Yeah as everyone explained, its the thermostat, mine was the same last week, I was on the motorway and it went all the right down to register nearly nothing. Changed the thermostat this week and it is now a rock solid 90deg always once up to operating temperature.
