?? temp only going to 80 deg
epox Nov 4, 2013
  1. epox
    epox Active Member
    773
    74
    hi
    as above temp guage is only going to 80 deg, have replaced stat and temp sensor.... any ideas
    thanks mark
  2. Westy
    Westy Well-Known Member
    17,443
    1,105
    There might be air in the system! Feel the radiator hoses when the car is up to temp an if one is cold (usually the top hose) it means you have air in there stopping the warm coolant getting round to opening the stat.
  3. epox
    epox Active Member
    773
    74
    hose did feel warm but not roasting .. whats the best way to bleed? did try running the engine with exp cap off..
    mark
  4. hades-
    9,481
    646
    run with cap off for an hour squish top hose aswell
    if no joy im sure theres a bleed screw somewhere
    i know there is on the b6 and b7
  5. Westy
    17,443
    1,105
    Be very carefully with the cap off! Have you seen Andrew@ALD's thread?
    Anyway, cap off, car running, whack your heating on full blast, keep giving the top hose a squeez and the air should work it's way round and out the header tank. You should see the bubbles. Stop once the stat has decided to get up to 90.
    Also I'm assuming you used a stock stat and not one rated at a lower temp?
  6. epox
    epox Active Member
    773
    74
    ye new stat from audi !! ye did see the thread ! scary stuff....you would think there would be a bleed screw handy some where?
    cheers mark
  7. hades-
    9,481
    646
    i forget about the heaters on full
    and as above is it a oem stat or aftermarket
    iv had problems with gsf stats in the past
  8. eightfour7two
    eightfour7two Member
    46
    Sorry to hijack the thread, but is the coolant temp supposed to rise to 90 and stay there? My S3 tends to sit at 80, but hits 90 after a hard run
  9. Westy
    17,443
    1,105
    Supposed to get there and stay there. I it fluctuates then the stat probably needs replacing.
  10. aragorn
    18,490
    855
    You dont need the heater on full.
    No idea why that myth perpetuates round and round the internet.
    The dashboard heat setting does not alter anything to do with the engines coolant flow.
  11. epox
    epox Active Member
    773
    74
    no luck.... gave the top hose a loads of squeez untill it haw to hot to touch but still sitting at 80, could this be bleed from the coolant sensor point?
    would there be an issue with the pump? had it replaced 1000miles or so ago.
    mark
  12. epox
    epox Active Member
    773
    74
    anyone?
  13. kelk11
    kelk11 Member
    112
    i had this same issue after i bought a cheap stat off ebay, replaced with a stat from audi and solved the problem.
  14. aragorn
    18,490
    855
    put the climate control into diagnostic mode and see what it says the temperature is...
    Hold down recirc and press the up arrow
    Display changes to 1c
    use temp +/- control to make the display show 49c
    Press recirc again
    Live coolant temperature will be displayed, you can then drive around and watch what it does.
  15. hoffmanvp3
    hoffmanvp3 Active Member VCDS Map User
    304
    81
    isn`t the green coolant sensor at the right hand side of the head prone to need replacing if your getting funny temp readings?
  16. aragorn
    18,490
    855
    They dont fail as often as folk seem to think, its usually the thermostat.
    In any case, hes already changed it!
  17. epox
    epox Active Member
    773
    74
    ye have replaced the thermostat from audi, have replaced green temp sensor not audi.
    aragorn are the temps shown taken from the green temp sensor?
    cheers mark
  18. aragorn
    18,490
    855
    yep. But the cluster adds in all sorts of buffering and hysteresis, the climate readout is a unaltered live display of the temperature.
  19. epox
    epox Active Member
    773
    74
    ok temp on air con only goes to max 75deg . mix of motorway and town driving. any ideas.
    mark
  20. RobinJI
    RobinJI Active Member
    178
    I'd stick another new stat in it personally. OEM doesn't necessarily mean infallible. Either that or test what temperature it actually opens at using a thermometer and a slowly heated pan of water.
    It's considered good practice as a lot of cars do control interior heater temperature by controlling the coolant flow through the matix. If you know for sure the car you're doing it on doesn't then fair enough, but it doesn't hurt to get into the practice of it in case the next car you're faced with does.
  21. aragorn
    18,490
    855
    I'd have said the stat is faulty, however you've now said you fitted a fake temp sensor. These can be hit or miss. Stick the original one back in and see how it changes. If it stays at 75c max then the stat is faulty.
  22. epox
    epox Active Member
    773
    74
    ye will try the sensor ...if that does not work time to whip out the stat.
    mark
  23. mattyboy199
    mattyboy199 Well-Known Member
    1,889
    29
    mark
    i have exactly the same problem as you i replaced the state & sensor back in feb, i bought a sensor off ebay so unsure if its genuine or not. Keen to hear how you get on with this as i havent the time to sort it at the moment.
  24. epox
    epox Active Member
    773
    74
    oem one out the scrappy...... quage back to 90d and ac unit reads around 93... issue seems to be cts.
    still think i have an airlock will run it for a while....aux water pump not running when engin ****ched off.
    anyone know how to change the temp reading on the dash from f to c as i adont know how i managed to change it.
    thanks
    mark
  25. ticketyboo90
    ticketyboo90 Member
    30
    Never buy cheap **** parts thinking you've saved yourself a fortune. If anything you'll have spent more because the cheap **** will last you a month or two and then you will have to buy the real thing. Don't buy an audi and put cheap tacky vauxhall Peugeot parts on them! Audi'so deserve to be looked after. Wether it's an 80 or an r8.
  26. epox
    epox Active Member
    773
    74
    ye thanks for the usefull comment....cheers mark
  27. mattyboy199
    1,889
    29
    Did you cure this with a new CTS ?
  28. epox
    epox Active Member
    773
    74
    ye mate all seems sorted, temp gets to 90 and sits there like it used to.
    mark
  29. mattyboy199
    1,889
    29
    Good I'm going to order a new sensor.
  30. aragorn
    18,490
    855
    What are your symptoms?
    Its almost always the stat.
    The problem here was that he had a knackered stat, then fitted a cheap CTS which was duff.
  31. mattyboy199
    1,889
    29
    I did exactly the same, my stat is a genuine VAG item but my sensor isn't.
  32. epox
    epox Active Member
    773
    74
    also getting mpg back to what it was...heating up faster= + 3 to 4mpg
  33. Jersey
    Jersey Member
    116
    14
    Ive been wondering about my temperature gauge for a week or so now. When i have the heater on it doesn't seem to get upto 90, hitting no more than 75-80. As soon as i turn it off. It rises to 90.
    Thermostat????
    cheers.
  34. buznout
    buznout New Member
    Had the exact same problem. Replaced the temp sensor, no change then the thermostat after which sorted the issue. Weak stat didn't stay closed for long enough so the engine only got to temp after a fair amount of driving.
  35. aragorn
    18,490
    855
    Almost certainly the stat.
    Jersey likes this.
  36. Jersey
    Jersey Member
    116
    14
    Cheers guys for your help, thermostat on order. Might even try and fit this myself!!! Just looking for a good picture guide, i'm sure there will be one on here somewhere.
  37. epox
    epox Active Member
    773
    74
    i posted details on the forum last week or so do a search for thermostas replacement.. was from the tt forum but same engine.
    mark..... no matter wats sait you can get to the stat bolts with a 10mm socket and a small ratchet..out of halfords pro socket set.
  38. mattyboy199
    1,889
    29
  39. Jersey
    Jersey Member
    116
    14
    Perfect cheers guys
  40. mattyboy199
    1,889
    29
    fitted my new OEM CTS tonight i'm quite suprised this cured the problem & relieved i didnt have to change the stat again. It also cured the hesitation issue from cold. Happy times !
