Temp Guage not working - coolant temp sensor changed
Johnboymason Nov 30, 2012
  1. Johnboymason
    Johnboymason Member
    73
    i bought my audi a4 1.9 tdi 130 se a few weeks back and the mpg is terrible round doors about 27mpg on a run about 38mpg and my temp never ever goes past 55 so ive changed temp sensor and its still the same with **** mpg just put £20 in yesterday done about 80mile and its gone, but it seems to vary off £85 at £1.39.9 a litre i only got just short of 400 miles and advice or has any1 had the same problem???? im going to change the thermostat tomorrow hopefully that works and d.i.y tips on how to change
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    If the sensor hasnt fixed it the the stat will
    tips yes watch the back of the alternator it will still be live and if you touch the wiring with a spanner you will get sparks!!
    when you come to put the new stat in put the new seal and stat on to the housing and rotate the stat 90 degrees the housing has two prongs inside it to hold the stat while you place it in to the hole in the block
    dont drop the screws they fall between the engine mount and are a pain in the ass to get out
    get some coolant to top it up
  3. Johnboymason
    Johnboymason Member
    73
    cheers stu where is the stat located lol
  4. stu_m
    1,441
    It's behind the alternator if you follow the bottom hose from the rad you will find it
  5. Johnboymason
    Johnboymason Member
    73
    cheers mate ive had enuf of it now im taken it back to the garage lol
  6. SL11CKK
    SL11CKK Active Member
    704
    37
    Dude its a piece of cake to do as I just did mines too today. The top screw is a piece of cake to get out and the screw on the bottom is a bit of a fiddle because of all the wires are there, however both are do-able if you have a medium length extension for the ratchet. Both screws are size 10.
    Honestly for me it was like an air filter change.
  7. Johnboymason
    Johnboymason Member
    73
    i cant find mine im useless lol
