Temp gauge not working
skinz Sep 18, 2011
  1. skinz
    skinz Member
    233
    My temp gauge has stopped working, I think it could b the thermostat or the temp sender but not sure where these are, any help would b much appreciaated, or if u have any other ideas what it could would help cheers
  2. aragorn
    18,297
    804
    If its the thermostat, the gauge will rise if the cars left idling.
    To test it, drive around for 10mins or so, then park up and leave the engine running for 5 mins. If the gauge comes up the stats gone, if it doesnt its probably the temp sensor.
  3. skinz
    skinz Member
    233
    Looks like it's the temp sender, where is it on the AEB engine
  4. skinz
    skinz Member
    233
    the dash temp gauge is for the water temp not the oil
  5. aragorn
    18,297
    804
    its on the back of the cylinder head, sticks out of a plastic elbow with a four pin plug on it.
  6. skinz
    skinz Member
    233
    cheers found it, had a quick look on fleebay an cant seem to find 1 that matches mine
  7. aragorn
    18,297
    804
    What year is your car?
  8. skinz
    skinz Member
    233
    n reg 96
  9. aragorn
    18,297
    804
    Hmm ETKA is a bit vague.
    Its either 058919501A (black) or 059919501 (blue)
    It suggests the black one is used upto the end of chassis code T, then the blue one is used from V onwards.
  10. skinz
    skinz Member
    233
    the stump bit is really thick and its black (that sounds really wrong lol), all the 1's i've seen are thin
  11. aragorn
    18,297
    804
  12. murdoch
    murdoch Member
    44
    mine seems to have stopped working for the last week or two aswell, although it climbed to 65c this morning ?? am i looking at a thermostat replacement?
  13. skinz
    skinz Member
    233
    nether of them 2 look like mine, ill put a pick up in a bit
  14. aragorn
    18,297
    804
    Murdoch: as i said above, have a drive to get some heat into it then leave it idling for 5-10mins and see if the temp comes up to 90.
    If it does, its the stat.
  15. skinz
    skinz Member
    233
    Can't seem to add pics
  16. aragorn
    18,297
    804
    upload them to photobucket or imageshack then post the link here?
  17. skinz
    skinz Member
    233
    At the bottom where it says posting permission it says I'm not aloud 2 add attachments, does that mean I can't put pics on, cause I click when I click on the image icon it don't do anything
  18. Geeman
    Geeman Low Life
    1,318
    Mine had similar symptoms. Changed the temp sender and it was fine.
    Also changed the thermostat, just to make sure!
  19. aragorn
    18,297
    804
    dont bother trying to upload them to the forum. Upload them to photobucket or image shack and paste in the link.
  20. murdoch
    murdoch Member
    44
    did so last night, no change in the reading, didn't go above 60c !
  21. aragorn
    18,297
    804
    sounds like it could be the sensor then. Do you have climate control?
    If so, press and hold recirc, and press the up arrow, the display will change to 1c, use temp +/- to change it to read 49c then press recirc again.
    The display will then change to show the real coolant temp. See what that shows?
  22. skinz
    skinz Member
    233
    Went Audi today and took my sensor with me an they said they had 2 order the sensor in and gave me the part no. Which is 058 919 501a which is the 1 u said but it don't look like mine
  23. aragorn
    18,297
    804
    could be revised over the years?
  24. skinz
    skinz Member
    233
  25. murdoch
    murdoch Member
    44
    ooh ooh, i like playing with buttons!! I will have a look at it tomorrow :) cheers
  26. murdoch
    murdoch Member
    44
    had a go with the climate thingy, and it read the same as the gauge, never went above 62c, is that a new sender or thermostat?
  27. aragorn
    18,297
    804
    did it sensibly climb up to 62 though?
    Ie start at 10-15c then climb steadily?
    Also, switch the AC off when testing, as with the AC on it runs the radiator fan all the time, and this will further reduce the temperature if the stat is stuck open.
  28. murdoch
    murdoch Member
    44
    I don't know, because I only got a chance to set it up at some roadworks, by which time it was up to 62c.Thanks, I will try that tomorrow, and have the ac off too!!
  29. skinz
    skinz Member
    233
    i dont have ac i dont think, but my fan is on all the time, should it b on all the time
  30. murdoch
    murdoch Member
    44
    Yes, the temp climbed steady to 65c, then fluctuated between 62-57c with all heating etc off, I lifted the bonnet whilst it was idling at the end of the journey, and noticed the fan was continuously on, is that normal?
    Skinz, sorry to jump on your thread, i thought it would be a good idea to keep it all in one, as it's effectively the same problem.
    Aragorn, thanks for helping !
  31. skinz
    skinz Member
    233
    No worries bud if it helps u out as well, I've got my mot coming up so just trying to get everything sorted for that, got my wish bones, ABS sensor an cv boot to sort out next, I'm hoping that's it all sorted for mot then
  32. aragorn
    18,297
    804
    Which fan?
    There are two. One large fan bolted to the engine and driven by the aux belt, and a smaller electric one.
    The big fan runs all the time, but has a viscous coupling and should only run slowly with the car at normal temperatures. The small electric fan should only run when the coolant temp is over 95c or when the AC is on.
    It does sound like the thermostat, especially if the bits where it dropped lower than 65 where high speed low load, like crusing on the motorway. Its odd that it wont climb when idling, but i guess if the stat was really jammed open the fan may well be drawing enough air thru the rad to keep the temperature from climbing any higher.
    The one last check you could do, would be to use vagcom to compare the ECU temp reading with the instruments, if they're the same its almost certainly the 'stat.
  33. skinz
    skinz Member
    233
    Went an got the temp sensor this mornin an it's all workin again, cheers for ur help (memo to self: don't take out temp sensor when engine is warm :-/
  34. shaneA4B6
    shaneA4B6 New Member
    My temp gauge is not working
    audi a4 b6 1.9tdi 130bhp
    i have hooked a diagnostic computer up and done a gauge test on it and all gauges move accept the temperature gauge during testing.
    anyone any suggestions or advice
    much appreciated
  35. jbh
    jbh TDi lover
    1,412
    164
    could be the cluster if the temp isint moving during a gauge test
  36. shaneA4B6
    whats the fix for this
  37. aragorn
    18,297
    804
    Either a new cluster or find someone who can repair it.
    This is the B5 subforum, your likely to find better model specific info in the B6 section if thats what you have.
  38. shaneA4B6
