Temp gauge fault
fallmonk Jun 1, 2013
  1. fallmonk
    fallmonk Turbo Sport
    1,868
    Currently having a intermittent fault with my temp gauge . Anyone else had this ?
    Sometimes it shows the standard 90c temp other times won't budge ?
    Any idea welcome
  2. fallmonk
    1,868
    Ps it's a 3ltr petrol cab
  3. quattrojames
    14,050
    573
    Coolant Temp Sensor or sticky thermostat would immediately spring to mind.
  4. pauldazzle
    pauldazzle Well-Known Member
    1,122
    80
    My money is on a goosed coolant temp sensor. Replace with genuine VAG CTS only.
  5. 666markyboy
    666markyboy Well-Known Member
    1,201
    49
    Yeah temp sender.... and if it dont stay at 90 , drops to around 70 and inbetween than thats a lazy thermostat
  6. Mike.M
    Mike.M Well-Known Member
    2,477
    169
    I would change both for peace of mind and buy some more G12 coolant too as you will need it to top the system up afterwards.
  7. A4WAGON
    A4WAGON New Member
    yes, I am having similar issue. I have 2004 1.8 Turbo Avant. Am in the US, so running on gas. Mileage is 70K. Just did timing belt and water pump, and while no issue with WP, it was preventative since car was all taken apart. During that service the error codes 17700/P1292 - MAP controlled Engine Cooling Thermostat - F65, open circuit, static; and 19497/P3041 - Databus drivetrain implausible engine temp message from instrument cluster. Can anyone help decipher? do I replace ECT sensor or Thermostat?? or both??
  8. pauldazzle
    1,122
    80
    Looking on rosstech, it's your coolant temp sensor, & the thermostat are goosed. Both are common failures.
  9. A4WAGON
    A4WAGON New Member
    Do you recommend DIY, indie garage or dealer repair?
  10. hodgy0_2
    hodgy0_2 Member
    97
    I replaced the coolant temp sender on my 2.5 TDI in about 10 mins, easy peasy
    Guage showed similar issues, sometimes would register no temperature
    No probs since
  11. boost-addict
    boost-addict Well-Known Member
    1,000
    both are very easy to do. two bolts on the thermo housing, pull a c-clip on the temp sender.
    change both mine and replaced the whole system with g12, behaved since.
  12. pauldazzle
    1,122
    80
    As stated it's an easy job to do both CTS & stat. Any independent garage could do it if your not confident to do it yourself, & absolutely no need to pay main dealer/stealer prices.
