Temerature Problem ???
Mrbullit Sep 9, 2013
  1. Mrbullit
    Mrbullit New Member
    22
    Hi guys just recently my temp gauge is showing some worrying signs.
    Normaly it stay's at 90 degrees Normal op temp
    But in the last week it is creeping over the 90 and up to 100 105 degrees im not sure why. When I Stop then the fan comes on any ideas :unsure:
    Coolant is fine do you think it might be a sign of the thermostat going ???
  2. Mike B
    Mike B Well-Known Member
    1,101
    40
    Unlikely cos tne stat should fail open which would not cause overheating.Probably the waterpump is going
  3. Mrbullit
    Mrbullit New Member
    22
    mmm actually I think now I have been having water come from my car on the floor but I thort this was the air conditioning unit ?? if it is my ater pump why has the coolant level nto dropped ?#
  4. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,912
    164
    Be sure that yu don't have any air in the system, mine shot up over 100c when I hadn't bled it properly
  5. Mrbullit
    Mrbullit New Member
    22
    I have no air lock in the system im going to change the thermostat as im sure this is the problem
  6. aragorn
    17,956
    701
    failed water pump sounds plausible.
    Mine worked fine if the revs were low, but bring it up past about 2-2.5k and the pump impeller would start slipping on the shaft and the temp would shoot up. slow down or stop and the impeller would grip again and temp would drop back down.
  7. Mrbullit
    Mrbullit New Member
    22
    Aragorn this is exactly the problem m8y ive got a day off work today so im going to have a look
