Tech Question - Boost
A4Andy Aug 4, 2007
  1. A4Andy
    A4Andy Quattro-tastic. Not half.
    458
    If I'm showing a steady 15PSI at the manifold via a boost gauge, where the ******* can my boost be leaking from?! When I accelerate while in turbo country, above 2.2k or whatever, I get a sound like an air compressor blowing; I mean it's ******* loud.
    Along with this comes retardation of performance, the car isn't anywhere near as rapid as it should be having been mapped. Forge 007 fitted 10K ago as well.
    So, before I trade her to some salesman that deserves all the misery that I can bestow up him, do anyone have any last ditch ideas?
  2. golf
    golf ***** rent boy VCDS Map User
    1,556
    What engine have you got?
  3. J7USS
    J7USS Shuddup Foooool!!
    3,737
    77
    Mine did this a while back, It sounded like a Hoover when I fling'd my foot down.
    Mine was the 6inch Vac pipe on top of the engine. Ill get some pics up to show you when I can take a shot
    Also I noticed my Main turbo pipe that runs into it was very loose when I checked.
  4. A4Andy
    458
    1.8T, 150 standard. Revo'd.
    J7uss, did you lose performance?
  5. james0808
    james0808 Active Member
    3,548
    You will need to check all your boost pipes,big intercooler ones and the vacuum ones for loose connections or splits.
    Check your diverter valve first though.
  6. A4Andy
    458
    It's showing 15 PSI at the manifold, after peaking at 18 PSI. The pressure is steady. After the manifold it's straight into the cylinders is it not?
    So where can it be escaping?
  7. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    a small leak would not be noticeable with your hearing
    if its a big leak and its loud then id check the large pipes
    especially the large one entering the turbo itself from the maf sensor
    after this check the intercooler pipes make sure there tight and no spilts in them
  8. A4Andy
    458
    All big pipes have been checked. Full boost is getting to the manifold...
  9. J7USS
    3,737
    77
    Yes I lost performance big style. I only found mine by chance.
    It sounds similar to mine, Il try and get pics once I get away from work.
  10. Elberoth
    Elberoth Member
    70
    Get someone with Vag-Com to check the Block 032 values. That will tell you if there is a boost leak or not.
  11. A4Andy
    458
    Top tip, cheers.
    What I don't understand is where it can be going. If full boost is available and showing at the manifold, where can it be escaping? Surely it goes straight from the manifold into the cylinder?
  12. claudefrog
    claudefrog Member
    372
    the turbo is just working a lot harder to supply the correct amount of boost.. I would get checking all hoses before driving too much harder, you will end up wrecking your turbo
  13. A4Andy
    458
    There
    Are
    No
    Leaking
    Pipes.
  14. golf
    1,556
    I wouldn't be so sure, Andy.
  15. A4Andy
    458
    If pressure is steady at 15 PSI, what pipes exist between the manifold and the cyclinders? :meeting:
  16. james0808
    3,548
    There isnt any,i think what people are saying is,have you measured boost at the turbo to make sure its not producing say 18 psi and your leaking 3 psi before it gets to the manifold.
  17. A4Andy
    458
    No, the turbo should be producing 15 PSI, peaking at 18 PSI. Also, if there was a leak before the manifold the preasure wouldn't be constant, it would fluctuated, the gauge is solid on 15.
  18. Rev-head
    Rev-head Active Member
    2,987
    PM sent
